Home > Maintenance & Modifications > height sensors and front suspension
PAS
England 2008 Range Rover Sport TDV8 HSE Santorini Black
having replaced upper/lower wishbones ,ARB & brackets couple months ago, ,I had it 4 wheel aligned at local main dealer,on first occasion they couldn't do it as they said the 2 front sensors (fault codes)weren't working correctly.this didn't make sense to me as it leaned slightly lower on drive side front and back ,they had to order them.took back to get them fitted then told the accelerater needed replacing.got that done ,the lean is worse,on the back when off road height there is a difference of 1 1/2".took straight back,was told as it has 22" wheels it makes it difficult,so on the next visit they plan to take off my wheels and put 19"on then set it up.since doing the alignment it seems the noise from suspension has come back.my questions ,if anyone could help please,are surely the noise shouldn't come back so soon!Are there any of the newer rrs fitted with22"as standard if so the tools should work on mineMine has not got the mass dampers on it .it is the v8 diesel on 58 plate.any ideas much appreciated. thanks p
Post #441392 Mon Nov 03 2014 3:45pm
