Home > Wheels & Tyres > 18" rims?
Badgermo
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
18" rims?
I am considering changing the wheels on my 59 3.0 hse rrs to 18" rims with grabber a/t tyres. I tow a 7m caravan quite often. any pros and cons and advice on widths would be very helpful.
Thanks in advance
Post #441214 Sun Nov 02 2014 11:09am
Somerset Bumpkin
2010 Range Rover Sport 3.0 TDV6 HSE Java Black
I think the smallest you can get is 19". I just bought myself a set of 15 spokes (from the SE) and they look great. Tyre size was 255 50 r19.
Funnily enough I used grabber AT on my 20s (275 45 r20) and they were perfect and much more comfortable than usual 40 profile road tyres. I just decided to get some winter rubber this year as the AT aren't that great on ice (although they're great in snow) which is pretty common.
Post #441255 Sun Nov 02 2014 4:44pm
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
If it were possible to get 18s to fit it would certainly be a smooth ride .
Post #441260 Sun Nov 02 2014 6:19pm
Badgermo
Thanks Guys.
I still cannot make up my mind.
Post #441324 Mon Nov 03 2014 7:36am
Badgermo
Just in case anyone is interested;
http://www.wheelbasealloys.com/alloy-wheel...ss/18-inch
I have been in touch with the manufacturers and the rims are rated 1035 lbs.
What size tyres would anyone recommend.
Post #441400 Mon Nov 03 2014 6:05pm
crammy
United Kingdom 2007 Range Rover Sport Supercharged Stornoway Grey
I think at a rough guess 1035 lbs is about 480kg. Not got a calculator to hand but that near enough
Post #441406 Mon Nov 03 2014 7:03pm
Those rims will not survive the weight of a RRS if they're rated at only 1035lb. You need about 2000lb.
Even sat with all four wheels on level ground they'll be overloaded. The RRS weighs about 5500lb before you put any people in it. 2012 SDV6 - it's missing a couple of cylinders
Post #441420 Mon Nov 03 2014 9:43pm
JamesRoberts
United Kingdom 2005 Range Rover Sport TDV6 SE Cairns Blue
I have 18s on mine. Here's some originals for sale on eBay the same.
Item number eBay Item No. 361077460668
Post #441428 Mon Nov 03 2014 10:45pm
Badgermo
Just a quick update.
I bought a set of 18" AEZ Phoenix high gloss rims with GG A/T tyres 175x55x18".
When I first fitted them they were binding on the caliper.
I removed the wheels and removed the high spots from the calliper with a grinder re-fitted the wheels with no problems.
The ride is great and the rim protection is more than welcome.
I have include some photo's if you would like to see how they fit.
Post #442805 Mon Nov 17 2014 9:41am
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
What's the load rating of the wheels? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #442827 Mon Nov 17 2014 2:23pm
Badgermo
1025kg
Post #442842 Mon Nov 17 2014 4:59pm
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Badger, is that tyre size correct? Have you got a side view photo of your car? I've been given some FFRR 5-spoke 18's which touch the calipers! How much did you have to grind off?
Post #443570 Mon Nov 24 2014 11:05pm
Badgermo
Hi Salisburylander
Yes the tyre sizes are correct, but I don't have any photo's yet.
I reckon I took 2-3mm off each caliper.
Post #443696 Wed Nov 26 2014 10:04am
Salisburylander
I only asked because I've not seen them in 175/55-18 before and that size isn't listed on GG's website!
Post #443891 Fri Nov 28 2014 2:18pm
Badgermo
Hi Salisburylander
The people that supplied the rims also want some pictures so I will try to get some this week.I got the rims from Wheekbase alloys and they state that they fit the rrs (although they did not know that you have to relieve the caliper).
When I suggested that I was going to try to grind the caliper they advised me not to.
So far no problems. Smile
Sorry I don't know what GG is.
Post #444135 Tue Dec 02 2014 9:29am
