Home > Technical > Steering issue??
0ane
England 2007 Range Rover Sport TDV6 HST Java Black
Steering issue??
Hi guys got a weird one for you.. All of a sudden the Steering has gone heavy.. It's not always like this just when you go side to side.. Best way to describe it is that when you turn a corner usually if you let your hands off it will turn the steering wheel back near central where as all of a sudden mine dosent! If you left it, it would just keep going round! Any idea what this could be? I've checked the power steering fluid and there's plenty in! All tyre pressures are correct too! It's not Undriveable but just feels heavy on the turns all of a sudden... Thanks in adavance
Post #440506 Sun Oct 26 2014 4:38pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
its the uj at the bottom of the steering column , mine was the same took it off wd40 free it off good as gold or you could buy a new one
Post #440508 Sun Oct 26 2014 4:52pm
Disco_Mikey
RRS has a Servotronic valve on the steering rack. Very common for wiring issues to this valve, causing heavy steering.
If there is an issue with this valve, there Will be a fault code stored in the Air Suspension module for the valve Thumbs Up
Post #440512 Sun Oct 26 2014 5:08pm
0ane
There's no fault codes stored.. So the UJ where is this located and how easy is it to replace?
Post #440926 Thu Oct 30 2014 11:40am
Disco_Mikey
QMN500240
Around half an hour to replace on a V6, little longer on the V8's
Bolts onto the steering rack
Post #440928 Thu Oct 30 2014 11:53am
jprr
2011 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Hi
I have a similar problem on my 2011 RRS. Did you resolve? what was the issue?
Thanks
Post #459860 Mon Apr 20 2015 1:28pm
0ane
WD on the uv joint and has been fine ever since mate
Post #460008 Tue Apr 21 2015 2:23pm
jprr
Thanks for the prompt reply. Is there a diagram or instructions for oiling the steering column and associated areas that need oiling?are they easy to get to for a competent DIYer??
Thanks
Jig
Post #460010 Tue Apr 21 2015 2:26pm
Brooksey90
2006 RRS heavy steering
Hi I've just bought my first RRS last week and I think the steering is faulty I've had discos before and driven other range rovers but this one just seems real heavy at all speeds it never changes. Lock to lock is smooth and the wheel centres it's self after turning could anybody shed some light please I've checked fluid level is correct and I have no leaks.
Cheers Liam
My new toy
Post #478341 Sat Oct 31 2015 12:47am
Brooksey90
Hi I've just bought my first RRS last weak and I think the steering is faulty I've had discos before and driven other range rovers but this one just seems real heavy at all speeds it never changes. Lock to lock is smooth and the wheel centres it's self after turning could anybody shed some light please I've checked fluid level is correct and I have no leaks.
Cheers Liam
My new toy
Post #478342 Sat Oct 31 2015 12:49am
