Home > Wheels & Tyres > Best place to buy a spare wheel
Johnboys40
United Kingdom 2009 Range Rover Sport TDV8 HSE Lux Bonatti Grey
Someone has cut the wire & stolen the spare wheel from TDV8. Where is the cheapest place to buy a replacement space saver wheel?
Post #439649 Fri Oct 17 2014 6:52am
martyn05
You could try ebay or similar to get a replacement, then get yourself a wheel protector like many of us here have fitted to our cars. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #439652 Fri Oct 17 2014 7:07am
Johnboys40
Yes have fried eBay none on there
Post #439653 Fri Oct 17 2014 7:10am
sparky8181
Use a dealer or breakers yard, spare wheels on ebay have probably come from some poor owner in the same situation as yourself, buying off the thieves you would only be encouraging them to go out and steel another one Thumbs Up
Post #439655 Fri Oct 17 2014 7:31am
Forum Sponsors might be able to help
The contact RLD for your protector, will save you a fortune when they try again to get the wheel
Don't forget the rear light screws also
Post #439662 Fri Oct 17 2014 8:11am
riverblanche
try a RRS specialist dealer they often fit larger diameter wheels to "up spec" the cars and may have either some std alloys or space savers round the back
Post #439848 Sat Oct 18 2014 7:42pm
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Only £80!!
Post #440683 Mon Oct 27 2014 9:18pm
SRE
Spain
PM Dan at Duckworths, I bet he will sort you out, plus this gives you the chance to fit a proper size wheel under the arse end In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #440714 Tue Oct 28 2014 9:28am
