Home > Technical > Suspension Warning light
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi guys
Suspension warning light has come on suddenly, battery is fine have tried taking leads off battery to reset fault but no joy.
Compressor was changed two years ago suspension does not raise at all and is stuck on the low mode.
As soon as the button is pressed fault message comes on dash.
Any ideas ? Any help would be appreciated.
Post #440213 Wed Oct 22 2014 8:28pm
Here is the workshop manual section on the suspension system including fault codes and diagnostic clues. It's in 4 parts because of the file size limits of the gallery.
http://www.rrsport.co.uk/gallery/albums/us...%20pt1.pdf
http://www.rrsport.co.uk/gallery/albums/us...%20pt2.pdf
http://www.rrsport.co.uk/gallery/albums/us...%20pt3.pdf
http://www.rrsport.co.uk/gallery/albums/us...%20pt4.pdf
Hopefully you can find some ideas in there. It sounds like either a fault with the controller (including perhaps a blown fuse) or a ride height calibration corruption / height sensor issue. 2012 SDV6 - it's missing a couple of cylinders
Post #440228 Wed Oct 22 2014 10:40pm
Harry HST
I think i'm going to have to get someone to connect the diagnostics machine to pin point the fault.
Post #440282 Thu Oct 23 2014 4:54pm
