![]() | Home > Faults & Fixes > Battery Problems - Please Help ! |
Have you had your alternator checked? |
Lewis-Oddie Member Since: 25 Sep 2014 Location: UK Posts: 14 ![]() ![]() ![]() |
Thanks for reply. No, haven't had it checked as I assumed the alternator must be working fine because it shows the battery voltage as being 14v when running? |
Temperamental things these range rover sports when it come to the electrics. |
I've often wondered but do theses engines use any form of glow plug or heater during startup ?. On mine, if i start after it has been in its nice warm garage all night it turns over almost immediatly. If it has been standing out all night it may take 5 sec's or more before it will begin to turn over after pressing the start button. During this time there is a "heater" icon of sorts ( amber coil ) displayed on the dash.
"do theses engines use any form of glow plug or heater during startup ?"
Are you checking the voltage at the battery terminals? - some circuits run on a stabilised supply which is less. |
Ok so i've just been and purchased a multimeter and first tested the old battery which I replaced, that is showing 12.7 volts despite not being on the car since yesterday. The new battery is showing 12.4-12.5 and 14.4 when running so obviously i've mis diagnosed the fault and purchased a batter for no apparent reason!
Is it spinning the engine as normal or is it slower and sluggish to turnover? -check all terminals to/from starter, battery etc. especially all earth straps
Dan Stevens Member Since: 19 Aug 2013 Location: Brisbane Posts: 47 ![]() ![]() ![]() |
could also be the starter motor on its way out. |
