![]() | Home > Technical > Front & Rear brake disc removal |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
should be very simply as I did mine recently. I would say the trickiest part was removing the caliper carrier bolts. Spray a little wd40 on them. and remember to replace the carrier bolts with new ones! I broke one of mine when I went to tighten it again. only cost about a tenner for all 8 from advance factors.
Rudimax Member Since: 23 Nov 2013 Location: Lincolnshire Posts: 30 ![]() ![]() |
Cheers Buddy. Will have a go at mine 2moz. |
take a look at the "how-to" sticky if you haven't already, and bodsys brake bible |
Pretty straight forward. The brake bible doesn't cover the brembo fronts, but they're pretty simple if you follow the same principles. |
Fronts Done. All good. Now to do the Rear. |
