![]() | Home > Maintenance & Modifications > Changing the master cylinder |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Yes, you can bleed in the traditional way. You may have to bleed as far as the ABS modulator first, to get the fluid moving, then at the wheels.
K80tcg Member Since: 29 Mar 2013 Location: Verwood Posts: 25 ![]() ![]() ![]() |
Thanks for that.
I just cracked a pipe union on the ABS modulator and bled in the old fashioned way, with an assistant pumping the pedal.
