Home > Faults & Fixes > whistle on accleration |
Hi, how loud is it? Very slight might be OK - my TDV8 has always had a slight whistle. It can be a leak somewhere around the intercooler pipes or even on the charging side of the turbo. If it is loud it could be indicative of failing turbo bearings causing the turbo fan blades to touch the housing. You would only hear that on boost I think. 2008 MY Java Black TDV8 HSE
Sun Sep 28 2014 8:09pm |
Dan Stevens Member Since: 19 Aug 2013 Location: Brisbane Posts: 47 |
check all air pipes are tight.
Tue Oct 21 2014 1:11am |
