Home > Faults & Fixes > heated seat advice
wilpert
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
heated seat advice
im looking for a bit of general advice, my rr is quite new to me, so im still sussing out the foibles.
the latest one 9for now and I know there will be more) is that when I put on the heated seats, the lights come on but they don't seem very hot at all.
Question is:
Do the heated seats heat up to a certain temperature, i.e. could it be that they work but it wasnt nocieable due to it being a hot day when I tried them out?
Post #428317 Wed Jun 25 2014 1:07pm
martyn05
they have 2 heat settings, press twice for max heat. They do get pretty warm after a few minutes and you will definitely notice it ! 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #428325 Wed Jun 25 2014 2:21pm
wilpert
hmmm.. that tells me that something is not quite right then, as i did this and they just dont seem very warm at all.
Is there a particular fuse that may need replacing, or would it be the case that if the lights are on then the seat should be warm, i.e. both work or not at all?
Post #428339 Wed Jun 25 2014 3:16pm
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
They tend to get hot pretty quick when the engines running.
Unless you have a blown fuse, check the fuse , it could be just a simple fix as a fuse.
Post #437452 Mon Sep 22 2014 10:01pm
Both seats? ON THE WAY: BMW F21 M140i
Post #437522 Tue Sep 23 2014 6:40pm
Seeing that your vehicle is a TDV8, I would get your battery and alternator checked. It could be early signs of one of them failing. Common fault on early TDV8. Whistle
Post #437534 Tue Sep 23 2014 8:17pm
