Home > Technical > Speedo discrepancy?
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Speedo discrepancy?
In a nutshell, my speedo reads 70 and when I put my cruise on, it reads 72? (i.e the digital speedo on the cruise reads 72 )
edited as I got the figures around the wrong way
Post #436889 Wed Sep 17 2014 8:28pm
stealth
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Mines reads a little slow
Post #437142 Sat Sep 20 2014 10:26am
micalee
Cheers for the response
Post #437144 Sat Sep 20 2014 10:27am
Brian
Scotland 2013 Range Rover Sport SDV6 HSE Stornoway Grey
As does mine. Cheers
Brian
Owned: '13 HSE Black Edition 3.0 SDV6 Stornoway Grey
Gone: '57 HSE 3.6 TDV8, Zermatt Silver
Gone: '02 Discovery 2 TD5
Post #437216 Sat Sep 20 2014 7:45pm
micalee
So, guess we all have to be careful through the speed traps then as our speedo's read wrong!
Post #437231 Sat Sep 20 2014 8:15pm
drdelrrs
Speedometers on most cars are optimistic reading higher than your road speed so if your speedo say 70 your road speed will be lower ( and you'll be inside the law.
I think Type Approval construction regs say the accuracy has to be 10% at 30mph.
Post #437323 Sun Sep 21 2014 3:11pm
micalee
But it's the other way round unless I am confusing myself. My speedo says 70 but cruise says 68 and i guess my cruise is more accurate in which case when my speedo says 70 I am actually doing 72
Post #437337 Sun Sep 21 2014 5:50pm
RRS Daz
I've just done a test on way home.
Set cruise at 70mph on the dash.
Speedo shows less than 70mph (I'd say one little line less)
Reset computer and average speed says 67.8mph
I should of put a GPS device on to see what that said too.
Post #437345 Sun Sep 21 2014 7:19pm
micalee
Im gonna try my TomTom and see who is lying - speedo or GPS! I know you get a fudge factor with speed limits, but don't want to be doing 70 when I am actually doing 72/73!
Post #437346 Sun Sep 21 2014 7:25pm
Read that again. You've just confirmed that your cruise is more accurate than your speedo so, if your cruise says 68 when your speedo says 70 then you're likley to be doing 68, not 72. 2012 SDV6 - it's missing a couple of cylinders
Post #437348 Sun Sep 21 2014 7:26pm
micalee
Yes you're correct - I knew I confused myself!. When I have had my TomTom on with other cars, my speedo has always read higher (i.e speedo says 70, TomTom says 6Cool where as this is the other way around (i.e speedo says 70, cruise says 72)
I got the original post the wrong way around! my mistake.
Post #437351 Sun Sep 21 2014 7:42pm
