![]() | Home > General > MY2010 Plus Ease of Stealing |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Why not leave the key a couple of feet away and then check the door if you are concerned it isn't locked? MY16 AUTOBIOGRAPHY Indus silver with some toys
DaveB Member Since: 11 Aug 2014 Posts: 38 ![]() ![]() |
Yes, I can do that, good point. My concern though isn't really if the car is locked but how secure is it when it is locked and is hearing the locks fire and seeing the indicators flash, mirrors fold in etc. enough to know it is locked? |
As secure as any other car. They would have to break in to access the obc. By breaking in, that should sound the cars very faint alarm which really wouldn't scare a cat. If your car isn't keyless, then i wouldn't worry as they will need the key to disengauge the steering wheel lock. Don't let this spoil the enjoyment of your new motor. If your really concerned, nip down to halfauds and buy a steering wheel lock. |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
Speak to Anthony at Securemycar
I saw the other thread on Securemycar which is one of those that sparked this concern with me but I'm still questioning how valid the concern is. The securemycar site suggests the thieves can gain access to your car without breaking anything from which they can then use the ODB port to make a new key... I find this confusing? How do they gain access without breaking anything if they don't already have a key unless they are 100% reliant on you not locking it? If the car doesn't lock as it should, because they are blocking the signal or whatever, then surely you wouldn't hear the doors lock, the indicators wouldn't flash etc etc????
They're professional thieves so why would they let you know how they do it?
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
You risk getting your car stolen with a new alarm or not either way. Most are stolen by professionals, this is what they do. If you are really worried get a steering mounted stop lock as has been suggested. Having said that, I could undo one of these quicker than plugging into the ODB port.
Companies can disable the OBD port when the alarm is set |
Dave, not everyone looks and listens to see their car lock on pressing their remote, most people press the remote on walking away from their car usually with their back turned towards the car and just expect the remote to do its job. What these guys are doing is intercepting the signal when you are pressing the remote and this stops the car from locking so that they can then just open your car door without the alarm going off, plug in their hand held device, swiftly reprogramming their own key all with in 30 seconds, and away they go. If your vehicle requires you to put its key in the ignition and not a keyless start then your car is much safer than the 2011 MY onwards vehicles. My motor is keyless but i always press the button on the door to lock it. Another trick the thieves are using is that they will somehow cause your alarm to activate while hiding within range of the vehicle, then when you press your remote to cancel your alarm, then press it again to reactivate the alarm, as many unsuspecting people won't bother to check why the alarm was activated, simply just reset it from within their home and thats when the thieves block your signal, and then they are in to your vehicle and away they go. |
Thanks Ady, that basically confirms what I thought I'd understood from the various threads, but I do appreciate the confirmation as often the facts can get lost in all the different posts. I do have keyless entry on my RRS and so it is one of the 'affected' vehicles, however, although I've never had such before I've already formed the habit of locking it from the door handle buttons - probably because I'm too lazy to get the key out of my pocket |
