Home > General > steering wheel shudder
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Oh dear. Was not wanting to read that. What should I have it checked for?
Post #435564 Sun Sep 07 2014 7:18pm
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
I really can't help..... I sold mine while under warranty...
Does the wheel wobble get even more intense when breaking at motorway speeds...
Under warranty ... just let your dealer investigate.... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #435590 Sun Sep 07 2014 9:45pm
designboy
No but sometimes at around 30 I feel it, I'll keep a closer eye on it tomorrow, it does not seem a concern, but if its something I can catch now, then I'm going to get it fixed. When I say warranty, its the second hand dealer stuff - you know, the one you know really means nothing Wink
Post #435598 Sun Sep 07 2014 11:11pm
simple1
designboy wrote:
I get a vibration on the wheel when driving sometimes, not all the time though. Just assumed it was part of the car. Should I be looking for something more? I've it under warranty now, so best find it before it expires.
If you get this sometimes, it is likely the tyres are flat spotting when you park. 2.5-27 tonnes sat on four patches on warm tyres does have an effect, mine did this regularly when parked up on Tarmac or concrete, so parked it on loose floor in barn if not being used. When it did happen, a drive up and down the bypass with two roundabouts got the tyres warm and round again and vibration would clear. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #435606 Mon Sep 08 2014 5:48am
designboy
Cool. I'd left this morning to drop the kids off; it vibrated at 50mph but I usually have my hands on the wheel and never noticed. Though a run of about 10mins around 60 mph it's not as apparent. So I'm hopeful it's tyres. I'm not freaking about it as it's very mild. It's not like it shakes in my hands. More just when your not holding the wheel.
Post #435617 Mon Sep 08 2014 8:11am
andman
M40CCA seems to have the same problem....
You are clearly not alone
scott1963... have you resolved your problem... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #436973 Thu Sep 18 2014 3:53pm
m40cca
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
I do have this exact problem changed all sorts ov things wheel bearings, track rod arms, bushes the lot
In my 2nd set of discs and pads fitted today need to bed them in to see if it's cured it
Post #436994 Thu Sep 18 2014 6:22pm
m40cca
Drop link arms, top and bottom ball joints and new rear brake switch
Post #436995 Thu Sep 18 2014 6:34pm
m40cca
Have you checked your caliper pins to see if they are not stuck?
Post #436996 Thu Sep 18 2014 6:37pm
andman
Wow....Sincerely hope you crack it this time..... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #437014 Thu Sep 18 2014 8:10pm
m40cca
So do I andman, I really like the rrs but it's annoyed me that much trying to solve this problem I started to hate even driving the car now Big Cry
Post #437016 Thu Sep 18 2014 8:26pm
m40cca
Drove to hull this morning everything feels fine no wobble or vibration haven't been really jumping on brakes but at moment everything feels good. At least I've changed all the common wearing parts on my journey. But this must have been a collection of warped discs, the caliper pin been stuck and just needing a general clean in that area
But all Is good so far Thumbs Up
Post #437044 Fri Sep 19 2014 8:05am
andman
Fingers crossed m40cca... that is brilliant news.....
I could feel your frustration....I remember how scary that wobble got under heavy braking and how
utterly infuriating it was...
Post an update if all is going well.... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #437045 Fri Sep 19 2014 8:20am
BKHK
I had a similar problem in 2008.
Wheel balance - no.
New discs - no.
New pads - no
New tyres - no.
New wheels - no.
New steering rack - no
Next was the rear diff to be changed but since the car was less than 6000 miles, I refused to take it back and asked for a refund. In the end I was "assisted" by LR into a new car. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #437048 Fri Sep 19 2014 9:11am
scott1963
[quote="andman"]M40CCA seems to have the same problem....
new brembo discs and brembo pads everything ok for now thank god also replaced the passenger front calliper even replaced the calliper piston seals on both front callipers everything ok so far when replacing the front pads i noticed that there is a difference in pads the ones i took off were angled at both ends of the face the brembo pads are straight.there was the problem not getting the correct contact to the disc i have now learned not to cheep skate on my rr sport.buy the correct parts and dont go down the aftermarket root it is a false economy
Post #445326 Mon Dec 15 2014 4:39am
