Home > Faults & Fixes > Suspension goes into 'Extended mode' |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4409 |
More than likely a blocked air dryer, or a blocked exhaust valve
Mon Sep 15 2014 11:30am |
leedantex Member Since: 15 Sep 2014 Location: Manchester Posts: 7 |
Thanks for the reply.
Mon Sep 15 2014 11:44am |
Maybe also a ride height sensor.
Mon Sep 15 2014 11:53am |
The dryer can be emptied of its contents (silica gel and filters), and put together to test
Mon Sep 15 2014 11:55am |
Thanks Bodsy, I tried this yesterday and it SEEMS to be fine when on the 4x4 screen. The front 2 wheels lower at the same rate to access height then the back ones do not even try, they simply stay on normal mode height and the message pops up. There is no flashing or juddering on the 4x4 screen.
Mon Sep 15 2014 12:25pm |
Yes to both counts |
Mon Sep 15 2014 12:58pm |
Cheers |
Mon Sep 15 2014 1:01pm |
Okay so I have narrowed it down by hooking up to a computer and the faults are.
Thu Sep 18 2014 2:26pm |
Have you tried emptying the drier? |
Thu Sep 18 2014 4:12pm |
Tbh Mikey im nervous of getting to a point where I end up with a broken compressor off the vehicle and then im totally screwed. Or is it a doddle of a job? |
Thu Sep 18 2014 5:11pm |
Remove the bottom cover, take out 6 bolts holding the end cap on, fish out the internals, refit cap.
Thu Sep 18 2014 5:29pm |
When you say not recommended for long term use. What do you call long term? Is it not pointless then and just worth fitting a new compressor? |
Thu Sep 18 2014 5:43pm |
It's your money |
Thu Sep 18 2014 7:10pm |
