Home > Technical > Aftermarket head unit installation |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 |
LR have had amplifier problems with the Logic 7 system so it may be that the car you drove had this fault.
Sun Oct 30 2005 9:15am |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2581 |
Ditto: I think the Logic 7 is very well suited to the car, the first stereo I have had where I don't need the base cranked up all the way, there's plenty to play with. L319 D4 HSE
Sun Oct 30 2005 5:47pm |
Bontempi Member Since: 30 Oct 2005 Location: Where the gravel road ends... Posts: 17 |
Having heard other Logic 7 systems (for example in BMW), I am not so sure the system was broken.
Sun Oct 30 2005 7:05pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
I agree with Bontempi (sounds Italian!) I also found the HK Logic 7 audio system a bit disappointing for anything but movie watching on the RSE system, in which case it sounds great. For music, well... You should try turning Logic 7 off when listening to radio or CDs, I think the sound is better separated and less "muddy" that way, but still not as good as I expected after reading the specs of the system on paper. For instance, even with the active sub turned all the way up, I can barely hear any difference in bass when playing any source other than DVDs, and there is also quite a bit of rattling going on somewhere in my door panels when the volume is turned way up, something I will have checked at my first scheduled service. I don't think the system sounds bad, just not as good as many aftermarket systems you could get for a lot less money. It pales in comparison to the Dolby PLII factory system I had on my old Volvo S80.
Sun Oct 30 2005 8:30pm |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
Yes, the sound system is far from ideal.
Mon Oct 31 2005 4:37am |
Not sure it would look all that good either to be honest, and also more likely to attract the car stereo thief if there is something in there he can have away and sell on easily. L319 D4 HSE
Mon Oct 31 2005 7:28am |
I noticed the same thing. My guess is that the Logic 7 stuff digitizes the analogue signal from the tuner or CD, to apply DSP processing, and that this degrades the signal. Question is whether the "Logic 7" system performs better than the "Premium" system with the Logic 7 stuff turned off?
My current car has a custom installed Nakamichi head unit with Steg amps and MB Quart speakers. It outperforms the Logic 7 audio by a large marigin , although it is drowned by the louder engine and other noises... This system costs about as much as the Logic 7 system.
I can understand that the car manufacturers want their share of the money customers spend on 3rd party audio. But it is a bit irritating that they make custom installation harder or impossible. /Bontempi |
Mon Oct 31 2005 2:58pm |
Well, I don't look that good myself, so I don't think the different front panel will distract people anyway. Do you wear clothes that match the interior? I live in a rural area where we rarely have to lock the doors... Cheers, Bontempi |
Mon Oct 31 2005 3:02pm |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
Unfortunatey the RRS is built in Britain where leaving the car unattended for the shortest of moments would require the presence of a personal bodyguard and well positioned snipers " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Mon Oct 31 2005 3:58pm |
What does the "settings" menu do? What functions does it cover? Regards, Bontempi |
Sun Nov 06 2005 10:06am |
It allows you to enable, dsable or change settings such as headlights off delay, lazy entry, dipped side mirors on reverse, kilometers or miles readouts in the on-board computerr, auto door lock, trip computer reset, etc. |
Sun Nov 06 2005 3:27pm |
I was hoping it would do less than that... Thanks for your reply. Regards, Bontempi |
Sun Nov 06 2005 4:39pm |
