Home > General > extreme wobble when braking ##please help~~~
Page 3 of 4 <1234>
Bodsy
Site Sponsor
Try here for fronts
http://www.advancedfactors.co.uk/010ab-bre...5310-p.asp
Rears
http://www.advancedfactors.co.uk/010bb-bre...5311-p.asp
Doesn't include epb shoes. Discovery 3 and Rrs are the same for brakes on the std brake setups. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #436774 Tue Sep 16 2014 11:26pm
m40cca
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
thanks for that bodsy think ill go down that route now, is there a need to change the rears as they are new as well because im 99% sure the wobble is coming from the front end of the car
Post #436793 Wed Sep 17 2014 8:52am
Bodsy
Site Sponsor
Is there a Need? No, but having run my car for a couple of months on the front V8's only, (which improved the braking instantly) when I did the rears, it really made a difference overall.
My recommendation would be all, but if you only do one set, it needs to be the fronts first.
Check all the wheel bearings and bushes whilst you have it in the air as well, including the drop link bars. Thumbs Up Bodsys Brake Bible
See it HERE
Post #436795 Wed Sep 17 2014 8:55am
m40cca
that's what route I went down after the new discs bodsy I changed 2x front wheel bearing, 2x front sway arm bushes, 2x front upper ball joints, 2x front lower ball joints 2x front drop link arms and check all rear bushes in front and lower arms!!
Still no change Big Cry
Post #436797 Wed Sep 17 2014 9:00am
m40cca
The car doesn't do it when it's cold eg when the brakes are first used
Post #436804 Wed Sep 17 2014 9:43am
simple1
That's cos the discs are cold and haven't distorted. Once they build up heat they move which points to something seized. Once a disc has distortion it will never go away so replace them along with the calipers. If you read back to the beginning if the thread, it was suggested you check runout or disc distortion, if you haven't then you will keep chasing your tail. Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #436809 Wed Sep 17 2014 11:37am
m40cca
I've ordered the brembo v8 conversion today with new caliper holders, will I need to order new calipers as well??
Post #436810 Wed Sep 17 2014 11:50am
simple1
If the kit is just the brackets and bolts then you need pair of discs, set of pads and two calipers. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #436815 Wed Sep 17 2014 12:30pm
m40cca
It comes with new caliper carriers, brembo discs and pads I was under the impression you left the original calipers on the car
Post #436817 Wed Sep 17 2014 12:36pm
simple1
If the originals are Brembo then yes, but then you wouldn't need the kit.....so two calipers needed. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #436818 Wed Sep 17 2014 12:39pm
m40cca
I've just spoke to advanced factors and the kit contains brembo brand discs and pads for non brembo cars and they will work with original calipers just need to change the carriers
Post #436821 Wed Sep 17 2014 12:51pm
simple1
🙈 don't see the point in that. Having fitted a Brembo kit to our disco, which meant fitting discs and new calipers I m lost as to what the point of fitting discs and pads but retaining original calipers as they don't have as many pistons. Each to their own.... 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #436824 Wed Sep 17 2014 1:01pm
^^^ - agreed. Surely the point of 'upgrading' to Brembo's is for the increased stopping power of the bigger calliper/more pistons. ON THE WAY: BMW F21 M140i
Post #436826 Wed Sep 17 2014 1:19pm
Bodsy
Site Sponsor
The disks are bigger than std, the caliper carriers move the pads further out, so braking power is improved along with cooling on the bigger disk.
This is the setup on the V8 (Petrol) RRS and D3.
There is another mod you can do which requires changing the calipers, and using the setup from the 2010 onwards RRS/D4 Thumbs Up Bodsys Brake Bible
See it HERE
Post #436829 Wed Sep 17 2014 1:34pm
simple1
That's the way I would go, bigger discs with two pot calliper makes zero sense, and doesn't increase braking efficiency, so having bigger discs is only for heat dissipation which no one needs unless towing down hill a lot Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #436830 Wed Sep 17 2014 1:43pm
Page 3 of 4 <1234>
