![]() | Home > General > RRS 2011 TDV6 HSE Overheating |
Anything connected to the bottle is only a level sensor, the water temp sensor is in the inlet manifold. It is possible after 7 miles the thermostat hasn't opened so you will get local hot spots but if gauge reading normal then it will be fine, gauge/sender fault usually gives no reading or full gauge. The clips hold the breather for the washer fluid tank below 2x TDV6. SE and HSE. Both returned to sender with issues👀
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 ![]() ![]() ![]() |
Many thanks for the reply. I have attached three photos. 1. showing the pipe that I was describing that is not clipped in. 2. The temp gauge at 18.37 when I have just started the engine and 3. Temp gauge at 18.52 ie 15 minutes later after I have just driven about 6 miles. Outside temp is 24 degrees. Also from photo 1 I think I have too much coolant in the coolant bottle - what do you think?
Can anyone tell what the pipe in the photograph does and how it should be clipped in? Also any other thoughts on my overheating experience today? |
