Home > Maintenance & Modifications > Suspension fault - or is it brakes?? |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
All the symptoms of the rear brake switch. Cheapest option to try first as well. |
Sat Sep 13 2014 5:11pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Thanks. I think I will give that a try as a first step, unless anyone has any further thoughts?
Mon Sep 15 2014 10:54am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
Brake light bulbs will also cause this fault. Even cheaper and easier to try out.
Mon Sep 15 2014 11:32am |
Thanks DM.
Mon Sep 15 2014 12:09pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
The reason a brake bulb or switch throws up a HDC error and some other errors is that the HDC relay is hardwired in to the brake light circuit. This is because HDC activates the brake lights when HDC is controlling the vehicle's speed. An error in the circuitry means that HDC doesn't know if it's able to work properly so it throws the error. Terrain Response uses HDC so a fault on HDC will cause a fault in TR.
Mon Sep 15 2014 1:11pm |
Ahh, that helps clarify my thinking. Thanks very much.
Mon Sep 15 2014 1:17pm |
Well explained RRSTDV8 Just what i was going to say. |
Mon Sep 15 2014 1:19pm |
Well, I set about Black Bess with all the intentions of changing the brake light switch when I made a shocking discovery.
Wed Sep 17 2014 1:00pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 |
Has it had the brake vacuum pipe recall done to stop oil entering the servo?
Wed Sep 17 2014 8:56pm |
http://www.rrsport.co.uk/forum/topic16517.html before you ask where to find info about the servo recall... 2012 SDV6 - it's missing a couple of cylinders
Wed Sep 17 2014 9:04pm |
Vacuum is supplied by an engine driven vacuum pump on the diesels. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Sep 17 2014 9:08pm |
You took the words right out of my mouth RRSTDV8! My car was first registered on 01/09/2005, so it seems to pre date the recall. I certainly never received any notification.
Thu Sep 18 2014 2:05pm |
I have brought this back up to the top in the hope that someone with similar experiences can shed any light on the problem. I have yet to get into it in earnest, but the fault is still there, as described above and is really, really annoying!
Tue Sep 30 2014 9:54am |
Ignore the fact that it pre dates the re-call, ALL were affected and you should test the servo pipe for oil in it. If oil is present, get it to a Dealer and they should sort the problem out. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Tue Sep 30 2014 11:23am |
