Home > General > 6 head light bulbs !? |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
That would be the cornering lamp which can't be switched on manually. Only comes on automatically when you are turning (pretty sure you need to be indicating as well) at low-ish speeds. You'll notice it is pointing at an angle, to light up the corner you are turning into. |
Mon Sep 01 2014 4:32pm |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 |
cheers I guess the car has to be moving , when not moving indicator on and in drive the bulbs do not come on |
Mon Sep 01 2014 4:44pm |
Yes, the car needs to be moving but at a low speed so that the cornering light doesn't come on when you are changing lanes on a motorway for example. Take a look at the owner's handbook if you need more details. |
Mon Sep 01 2014 4:48pm |
thank you |
Mon Sep 01 2014 4:50pm |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
you dont need to have the indicator on btw.. |
Tue Sep 02 2014 9:10am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1831 |
Surely it does? How does it know which one to put on? 2023 P440e SE Dynamic on order -cancelled
Tue Sep 02 2014 9:11am |
May be it detects steering wheel angle. I never take a turn without indicating so to me cornering lamps only seem to come on after indicating. Will try without indicator to confirm. Btw cornering lamps should not be confused with adaptive headlamps which are not fitted to all cars. Adaptive ones actually rotate the main headlight beam based on steering wheel position and work at high speeds too. |
Tue Sep 02 2014 9:25am |
Tue Sep 02 2014 10:12am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Where adaptive lights are fitted, the cornering lights activate without a turn signal if the vehicle's speed is in the correct range. In the adaptive system, the "cornering lights" are called "static bending lamps" - they're the same bulbs in the same location but they are used differently.
Tue Sep 02 2014 11:48am |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
I love them, all but their horrible yellow colour, what bulb do I need to buy to make them match the main beam's 5500k temp? |
Tue Sep 09 2014 9:06pm |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 |
anyone got a pic of these lights ? perhaps a stupid question, but, how do you tell if you have them |
Wed Sep 10 2014 5:48pm |
Because they come on as you indicate and turn, just look at the ground as you next turn at night. 2023 P440e SE Dynamic on order -cancelled
Wed Sep 10 2014 5:54pm |
The only bulb pointing slightly outwards instead of straight ahead. This one:
Wed Sep 10 2014 6:29pm |
Ah , yep got them, horrible yellowish bulb, so as designboy said, what bulb and how to replace |
Wed Sep 10 2014 7:00pm |
