Home > General > extreme wobble when braking ##please help~~~
Page 1 of 4 1234>
m40cca
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
hi there im new to this site and really hope someone can help with my problem
i purchased a 06 range rover sport in may this year everything was fine and i really love the car first 4x4 ive owned well apart from a evo7!!
my problem started a month ago
ive started getting a really bad wobble through the steering wheel when applying the brakes over 50mph
Ive changed the discs and pads all round as this was my first thought and the most obvious still no change, I also greased all caliper pins and checked the calpiers in general
I then changed both wheel bearings no change
Had all 4 wheels balanced no change
Replaced anti roll/sway bar bushes no change
Replaced both front drop link bars still no change!!
Replaced top and bottom ball joints on both sides of front and still no change
Im really stuck as to what the problem could be,i know the symptoms point to something wrong with the brakes but like i say they have been changed all round with new brembo discs and mintex pads
Maybe someone on here has experienced this problem or seen a thread before
Any help or suggestions would be greatly appreciated as im getting really p***ed off with it because i really do love the car but its just getting me down driving it now with this problem
thanks again
Adam
Post #435280 Thu Sep 04 2014 8:18pm
simple1
More questions than answers but with a reason Big Cry
Does the vibration get less as speed diminishes, if you getting vibration, does the pedal bounce?
Are the discs genuine?
Have you got a mate with an engineering shop who can lend you Magnetic dti?
You are going to have to established if your discs are warped by this method. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #435282 Thu Sep 04 2014 8:42pm
mark.b
2007 Range Rover Sport TDV8 HSE Stornoway Grey
your tiers may have gone out of shape try swapping the back with the front ones
Post #435283 Thu Sep 04 2014 8:44pm
m40cca
Mark I've swapped the wheels from front to back
Post #435285 Thu Sep 04 2014 8:48pm
m40cca
Simple1 - the wobble/vibration isn't there at low speeds but I don't get anything through the peddle even at high speeds
What is this tool you ask if I can get hold of my uncle owns a garage so maybe he has one
Post #435286 Thu Sep 04 2014 8:51pm
mark.b
well it looks like the only thing you've not touched is the steering but i wouldn't know how to test it sorry
Post #435287 Thu Sep 04 2014 8:51pm
m40cca
I hope the discs were genuine!!!
Post #435288 Thu Sep 04 2014 8:52pm
m40cca
I was thinking this mark maybe the steering dampner and bushes next
Post #435290 Thu Sep 04 2014 8:57pm
simple1
Dial test indicator. Measures deformity in discs. It's not going to be steering rack or mountings, would do it all the time, hence asking about speed and pedal bounce. No bounce rules out discs, so as you have replaced bushes and ball joints you need to start looking at drive items. If you haven't replaced the arm bushes start there first as moving arms will cause the geometry to change when loaded under braking 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #435296 Thu Sep 04 2014 10:02pm
m40cca
Thanks simple1 these bushes you talk about are these the ones in the lower and upper front arms the ones which the ball hints are fixed to? Thanks again
Post #435297 Thu Sep 04 2014 10:06pm
simple1
Yes, they mount the arms to chassis 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #435301 Fri Sep 05 2014 5:56am
m40cca
Thanks simple1 I'll give these a try now then
Thanks for your advice mark and simple1
Post #435308 Fri Sep 05 2014 8:04am
simple1
Easy way to check these is to get someone to sit in car with foot brake applied and try and pull away while watching wheels. If they move back in arch bushes are shagged. In extreme cases, wheels will have back and forth play (front to back) while jacked up Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #435310 Fri Sep 05 2014 8:20am
m40cca
Simple1 I took your advice and changed all lower arm bushes and still there!!!!
The car feels a lot tighter now with the ball joints all done and bushes but the wobble is still there. The wife won't even drive it any more because of it. Any more advice boys?
Post #436193 Sat Sep 13 2014 2:39pm
Terryrrs
If you have checked run out on the discs as Simple1 has said and it's within tolerances then I would be looking at the calipers. The other thing it could be is brake transfer but if you have put on new discs and bedded them in it is unlikely.
Terry
Post #436195 Sat Sep 13 2014 2:55pm
Page 1 of 4 1234>
