Home > Maintenance & Modifications > Brake Pipes replacement on Range Rover Sport 2005-2009
Thebeloved
Luxembourg 2005 Range Rover Sport TDV6 HSE Santorini Black
Good evening all,
I would like to know if anybody changed the rear brake pipes on RRS 2005-2009? as they are corroded on mine.
Is it an easy job or is it very difficult?
How could you get to the pipes?
Did you have to lift the car?
Which pipes did you use as a replacement and from which place did you buy them? which tools did you use?
Is there any How-To guide for the RRS? any pictures? any thread dealing with this......?
I am planning to this myself this weekend and I appreciate any help. The Land Rover dealer wants about 1000 EUR to replace mine and they said it will take them about 5 h of work because they have to lift the body from the frame.
Before posting I checked the forum and online but there seem to be nothing related to the RRS.
Thank You all,
LY
Post #435133 Wed Sep 03 2014 8:42pm
Fish
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
I had my rear pipes changed out for copper by a local Landrover mechanic. He run the pipes from the front in to the rear with just the car jacked up at the rear and the rear wheels off, I can not remember if he had to remove any under shields. He had all the correct fittings and pipe forming tools to seal the ends, can't remember if it was flaring or bubble flaring tool kit he had. He did the job in under 2 hours.
Sorry I can't be of more help but you get the idea of time scale and it wasn't a body off job. 2.7 HSE, Audi A6 Exec, Honda Accord Exec, Volvo 440, Volvo 360
Post #435182 Thu Sep 04 2014 8:16am
Thebeloved
Thanks a lot for the valuable info. At least I know that I have to remove the wheels.
Post #435209 Thu Sep 04 2014 11:11am
flack
Just under the passengers seat is a heatshield, behind this are the two rear brake pipes, I cut these here and join with new copper pipe to both rear wheels job done in about 2 hours
Flack Thumbs Up
Post #435214 Thu Sep 04 2014 11:57am
RRS Daz
Have you cleaned the pipes off to check how bad they are or is a dealer/tester telling you?
Post #435217 Thu Sep 04 2014 12:03pm
Thebeloved
Thanks Das,
I saw that they are corroded. But I dont know if thats serious or not. The dealer said it is dangerous to drive with them like that.
Post #435240 Thu Sep 04 2014 3:30pm
Thebeloved
thank you Flack. Do you have any pictures??
Flack Thumbs Up
Post #435241 Thu Sep 04 2014 3:31pm
