Home > Technical > pressed air suspension whilst driving - now its playing up? |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
The pumps have gone in price latey. Mr dan @ duckworths is the man to talk to. If it has nt been replaced then at 100.000 it's done very well. You can keep using it as it is as it seems to work still and just live with the light coming on now and then but one day it will fail with the red light coming on. I payed £450 from duckworths with an indi charging 2 hrs to fit. |
Sat Aug 30 2014 2:58pm |
wilpert Member Since: 25 Jun 2014 Location: London Village Posts: 169 |
im prepared to replace it, i just dont want to replace it and then find its something else that causing the problem.
Sat Aug 30 2014 7:43pm |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
If one side is failing , you might need to look at the condition of the rubber boot on the air spring on that side, might be leaking, which means compressor has to work hard to keep up with leak - and this will accelerate wear on system. Soapy water sprayed on rubber boot might be needed to spot leak - and try this at full height, normal height (maybe hard to see at access height).
Tue Sep 09 2014 10:21pm |
Further development:
Fri Sep 12 2014 1:29pm |
