![]() | Home > Technical > pressed air suspension whilst driving - now its playing up? |
wot no replies? Come on chaps. I'm no expert but pretty sure pressing the button should have no effect at any speed above a crawl. You just get a message on the dash telling you not to be a silly boy as you are going too fast to select access height. Just stopping switching off and restarting resets everything, there's no special procedure. 2008 MY Java Black TDV8 HSE
wilpert Member Since: 25 Jun 2014 Location: London Village Posts: 169 ![]() ![]() ![]() |
Hello Paddi,
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
No servicing required unless you've had an actual problem with the pump itself. Eg not going up or down. Touching the button at speed should not effect the mechanics of the pump as I believe otherwise land rover would paint it red with a big warning not to press it above 30. try a hard reset if it it keeps playing up. |
Hello SCdavies,
Reset. Remove both battery cables from battery and join them together for a few minutes. This removes any un wanted voltage that could effect some systems. Or pop to a dealer and ask for a reset via your plug in. Drivers side under the steering wheel. In our cars the switch won't operate over 30 to lower or higher excess modes. On the monitor screen go into the 4x4 area and your ll see each corner of the car. Operate the pump switch and you should see each corner ajust. If it's doing what it should I think your pump s fine. |
Thats a comprehensive reply SC, i appreciate your interest.
If you have no codes showing then don't worry about a reset. It seems your pump is working fine so I would nt worry about unless any more messages show. But if you get a dealer to plug your car in the fault codes will stay until you get them cleared. I had mine done last and since new the car had 96 stored codes. |
I havent any faults showing, it went off after I stopped the car.
tailormadefun Member Since: 06 Apr 2014 Location: Kent Posts: 51 ![]() ![]() ![]() |
You may not have a fault showing on the dash, but a fault can still be stored in the ECU
just had a call from Mrs Wilpert, the suspension warning light is back on, she is going to the dealers today for a plug in to diagnostics. |
Update:
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 ![]() ![]() |
..sounds expensive. Had mine replaced with software update at my local main dealer about 18 months ago for just over �500 all in... Carl |
That sounds like a very good price to me.
Would nt pay more than �500 all in. It seems the pump has just got tired. Works ok but just slow. They have an average life of 60,000 miles. You can buy refurb kits for a DIY fix if you have a little mechanic in you. |
