Home > General > Help with torque wrench please!
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Bought my first ever torque wrench yesterday, usually just 'do things up tight' but thought I should do things properly with this car. Anyway, got a big 60 - 300nm wrench from halfords, with the help of a 45% discount via a blagged trade card, and thought I'd check the wheel nuts. Set the wrench to 140Nm and give it a go. I thought the nuts were already pretty tight but the wrench was not clicking, just tightened the nuts further, though it was very hard to tighten. In fear of braking the nuts (have snapped one previously) I dropped the wrench to. 60nm just to ensure it worked, but even at this setting it didn't click, just tightened further. Surely that's not right? Is 60nm difficult to achieve with a 55cm long wrench? I tried several nuts but all the same, wrench did not click even at 60....am I doing something wrong or do I need more time in the gym!!
Post #433978 Fri Aug 22 2014 9:03pm
aljo
The wrench is Censored ed , take it back Thumbs Up
Post #433981 Fri Aug 22 2014 9:19pm
Tony666
Cheers....will do.....so much for the calibration certificate that came with it!!
Post #433989 Fri Aug 22 2014 10:43pm
bigdavy60
2005 Range Rover Sport TDV6 HSE Java Black
could you be using it backwards ? it used to be possible but not sure if they make them like that any more where the drive slips back and forth to each side Rolling Eyes
Post #433990 Fri Aug 22 2014 11:07pm
Tony666
Can't see how? It's a push through type, ratchets one way then tightens the other, until it reaches specified torque then should click???
Post #433994 Sat Aug 23 2014 7:18am
bigdavy60
mmmm sounds like a trip back to where you bought it mate , good luck
Post #433997 Sat Aug 23 2014 8:23am
aljo
I've got the halfords pro 300 nm torque wrench which is probably the same one you have and very good tool
Definitely not a cheap and nasty wrench so obviously one that seems to have missed the quality control Thumbs Up
Post #434014 Sat Aug 23 2014 12:07pm
Tony666
Time to put my hands up and confess to being an idiot! Took the wrench to a mechanic mate who explained that you just got 1 click as your indicator of torque, I was expecting it to slip like a ratchet when it reached the required setting. That could have been extremely embarrassing had I taken the wrench back, especially as I'd told them yesterday I was a mechanic!! Feel free to take the p**s, I deserve it!
Post #434024 Sat Aug 23 2014 2:51pm
aljo
Whistle Laughing
Post #434028 Sat Aug 23 2014 3:25pm
Post #434031 Sat Aug 23 2014 3:41pm
mark.b
2007 Range Rover Sport TDV8 HSE Stornoway Grey
ooooooooops Laughing Rolling with laughter Rolling with laughter Rolling with laughter Now you know what to do Thumbs Up
Post #434039 Sat Aug 23 2014 5:47pm
