Home > In Car Electronics > Sat nav stalls on address input |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1833 |
Have you tried cleaning the DVD? 2023 P440e SE Dynamic on order -cancelled
Mon Aug 18 2014 12:08pm |
Is it set on the default country of UK.
Mon Aug 18 2014 4:44pm |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 |
With postcode you must use the space bar inbetween first and second half of code. |
Mon Aug 18 2014 6:35pm |
Onedeano Member Since: 17 Aug 2014 Location: Chichester Posts: 7 |
Yeah the default is on UK as checked. Basically, when I got to click on the square block that says 'address' - nothing happens! It stays on that page. I can't get to any point where I can type any address in! |
Mon Aug 18 2014 10:10pm |
How do I do this? It's not in the manual. There's nothing about navigation in the manual whatsoever! Tried googling all sorts of possibles! Thanks Dean |
Mon Aug 18 2014 10:12pm |
It's under the front passenger seat, clean as you would any CD/DVD 2023 P440e SE Dynamic on order -cancelled
Tue Aug 19 2014 7:28am |
Cleaned the CD and i still doesn't work - just doesn't go any further than the address button. Doesn't get as far as the address bar to input anything...! Completely at a loss with it. The manual has nothing about faults either. |
Tue Aug 19 2014 6:53pm |
You are tapping the white box and not the blue box with town etc on? |
Tue Aug 19 2014 8:08pm |
I can't even get as far as town options! The square address icon, I click it - and nothing!
Tue Aug 19 2014 8:11pm |
Have you looked at the manual on Topix?
Tue Aug 19 2014 9:17pm |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
disconnect the battery, leave for 30 mins and reconnect using the correct method.. |
Wed Aug 20 2014 10:46am |
Onedeano,
Thu Aug 21 2014 7:25am |
No luck yet guys... Going to try the disconnection of the battery tomorrow as recommended. Even the guys at a landrover garage, although just a quick look, were at a loss. Need it working for Monday! Try battery option tomorrow. I know the battery has just been put in before I bought as it was sitting idle battery less on forecourt.
Fri Aug 22 2014 9:09pm |
Not yet mate. Trying this battery disconnection tomorrow! Cheers |
Fri Aug 22 2014 9:10pm |
