Home > General > Starting issue
itsmeagain
Starting issue
Saturday my daughter was sick in the passenger seat of my 2010 RRS. Cleaned it all up and everything was ok over the weekend.
Today i gave the seat a freshen up cause i could smell it a little. Now my car wont start at all, totally no power. Start button does nothing.
Any ideas????
Post #433620 Mon Aug 18 2014 2:14pm
Disco_Mikey
Battery flat from having the doors open?
Post #433626 Mon Aug 18 2014 3:21pm
mlines
Which passenger seat, the main computer is under the driver seat 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #433627 Mon Aug 18 2014 3:21pm
itsmeagain
AA attended and diagnosed that the issue was a flat battery.
The guy came in a Land Rover/Jaguar branded van which was reassuring, he jump started the car and checked it over.
Apparently due to smart key being close to the car and the car not being started for a while plus the interior lights being on, the battery drained.
Seems ok now.
Post #433643 Mon Aug 18 2014 5:40pm
itsmeagain
Came out this morning, started my car and once again it was flat. As soon as i pressed the start button the clock began turning round and round. Anyway got the mrs car and jumped it then it was ok. Also got a error message, lean when cornering. Does this sound battery related?
Post #433757 Wed Aug 20 2014 9:30am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Yes i have had the same problems Battery going flat when doors were open when cleaning interia. When car was jump started all the info on dash went back to manufacture date, clock went to same time of manufacture. And all different faults came up ,Gearbox fault, Low fuel, etc. everything went back to normal after reset clock and date, and stopped engine and started it again. This happened to me twice,so i bought an upgrade 100ah battery. Because i was only doing short jouneys. Have had no problems since. itisme
Post #433763 Wed Aug 20 2014 10:03am
k9harrier
Our's does this after not running for a while. Generally only short trips too. Been in for numerous diagnostics but no one can find a problem but has killed 3 batteries in a year & getting very fed up with it.
Even after going out for 200+ miles on Saturday come Monday dead again Censored
Any ideas?
Post #433793 Wed Aug 20 2014 5:12pm
Sounds like a battery conditioner might be helpful. Leave it plugged in to the vehicle when you're not using it and it will look after the battery for you. The problem with occasional use is that, if the battery isn't in perfect condition then you might never get it fully charged even by a 200mile run.
Are you running the standard flooded lead plates battery or is it a newer AGM one? The latter is designed for use with stop-start systems so is a bit more resilient.
As for why it's killing batteries, have you checked the rear hatch switch? They corrode and can cause a short that kills batteries if left for a period of time. Very easy to replace - less than £20 to do it yourself in about 10 minutes. 2012 SDV6 - it's missing a couple of cylinders
Post #433817 Wed Aug 20 2014 8:38pm
Disco_Mikey
If the battery has gone flat, it will need fully charged with an external charger, to get it back up to 100% Thumbs Up
Just the way the "smart charging" system works Rolling Eyes
Post #433819 Wed Aug 20 2014 8:42pm
harrygh60
Any ideas?
Are you replaceing with the same type of battery ? I have heard different people saying that a battery is a battery. not true. It needs the same ah and possibly same CCA or higher. As been said before try the tailgate switch. I had battery problems when leaving the tailgate open. Doing various jobs Result no starter next morning Big Cry itisme
Post #433845 Thu Aug 21 2014 7:49am
itsmeagain
Where is the switch located? Do u have a part number?
Post #433847 Thu Aug 21 2014 7:51am
harrygh60
Its not the micro switch that corrodes, Its the alloy hinge device that pushes onto the switch that gets powdery and doesn't work properly. It is located under the rubber surround that you press to open top of tailgate. I have had this problem with both of my previous RRS. Toook them apart cleaned them and gave them some WD40 treatment ,Problem Solved itisme
Post #433866 Thu Aug 21 2014 10:33am
OP - Relating to the sick on the seat, get yourself some enzyme cleaner else the smell will never go away Wink
A couple of good ones:
Autosmart's Biobrisk - see ebay
Valet Pro Enzyme cleaner. ON THE WAY: BMW F21 M140i
Post #433871 Thu Aug 21 2014 11:14am
itsmeagain
Died again, wouldnt jump start so had to call out the AA. Eventually got it started then i delivered it back to the dealer. Hopefully its covered by the warranty.
Post #433892 Thu Aug 21 2014 3:03pm
itsmeagain
Dropped the car off yesterday afternoon and told them what the AA said. Even left the AA invoice explaining the fault, so car was being looked at today at 8.30am. I had to call them to find out what was wrong 2 hrs later only to be told it failed to start this morning. Another 2hrs after i called again it had been diagnosed as having a faulty cell in the battery. So i asked what they planned to do, said they've ordered a new battery. Unsure when it will arrive and unable to say if the warranty will cover the costs. Still waiting for them to say how much the battery is? And that was at 11.50am
Awful customer service again.
Post #433939 Fri Aug 22 2014 1:28pm
