Home > Faults & Fixes > Not changing gear!
BRO-T
Not changing gear!
Morning all,
I've had my 3.0 TDV6 RRS for 3 months now and its been back to the dealer 3 times to get this issues fixed. The car simply won't change gear correctly. I can be driving steadily about town, the gearbox automatically going through 2nd to 3rd about 200 rpm, then it won't change up into 3rd. I can be doing 50mph, and still in 3rd. I have to use the command shift to change to 4th gear. It's killing my MPG.
Anybody else had this problem. The dealership keep telling me it's fixed, yet the drive home proves the problem still exists. They changed turbo valves and all other kinds of solutions.
Should I get in contact with LR customer services?
Post #433573 Mon Aug 18 2014 8:29am
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
As silly as it sounds.... Check your tyre pressures !
Also if you have only had it for 3 months it's with checking you have the same make tyres on the back and the Fron two match ... And whilst your at it check the tread depth!
It's all about speed sensors! Any of the above will cause your issue
Hope this helps
Uk guy RRS HSE with a few extras & a
2013 RRS Autobiography
Post #433577 Mon Aug 18 2014 9:35am
BRO-T
Thanks UK guy. The tyres are all brand new which the dealer fitted prior to purchase and are the same make etc. I'll check the pressure later today.
Post #433578 Mon Aug 18 2014 9:41am
Disco_Mikey
Check your brake lights too Thumbs Up
A blown blub, or faulty brake pedal switch will cause exactly your symptoms Thumbs Up
Post #433613 Mon Aug 18 2014 1:04pm
