Home > In Car Electronics > Low power mode message on Stereo ?
customcarsuk
2005 Range Rover Sport TDV6
Hi
Finished work started the car up, windows down, sunroof open went to turn the cd up and had a message said Low power and volume would not go any louder.
Drop it up the road and it seemed all fine. No other warning lights on Dash.
Does this mean I have a problem with my battery?
I have to take it for a long run tomorrow and it has got me a bit worried.
Any ideas ?
Post #430965 Sat Jul 19 2014 12:44am
garrycol
Australia
Maybe but probably not.
When the battery is a bit down the car goes into a pretection mode to minimise power use - hence the low power message as the radios power is reduced. The next stage is the radio comes on but there is no volume at all.
Usually just running the car for a while and lifting battery charge is enough to get everything back to normal again. This issue by itself is not cause to think there are issues with the battery.
If the problem continues after a period of charging the battery then maybe.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #430967 Sat Jul 19 2014 2:11am
customcarsuk
Yesterday went to start it in the morning and the battery was flat, a day before the parking sensors stopped working.
Just fitted a upgraded battery today, Hope this resolves everything, will check it tomorrow when I take it to work. Thumbs Up
Post #433547 Sun Aug 17 2014 10:05pm
sparky8181
Thought this was just a protection method to stop excessive draining of the battery?
In your case, obviously your battery was knackered, now I might be wrong but I don't think that message is anything to worry about normally. I've always had the same message when using the stereo without the engine running since buying the car nearly 2 years ago and have never had a battery problem.
Post #433548 Sun Aug 17 2014 10:20pm
SRE
Spain
Can also be an alternator fault as well Big Cry In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #433569 Mon Aug 18 2014 8:19am
