Home > Technical > 3 x airbag faults
squizzel
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
3 x airbag faults
Hi all i hope someone can help.
I collected my dads 55 plate 2.7 diesel today as it is in for mot at 8.30 in the morning. As i was reversing off his drive the airbag light came up on the dash. I stoped the car and restarted it and the light never came on again all the way home. I have used the car another twice and twice the light came on, but i was reversing every time, this may be a coincidence.
I have put it onto a hawkeye code reader and i have 3 diffrent faults.
B1A00....control module circuit voltage below threshold.
U0073.....control module communication bus off.
B0001......driver frontal stage 1 deployment continuous (subfault) circuit resistance above threshold.
So does anyone know what all this means, could it be a loose connection on the airbag ecu, and if so where is the ecu.
If anyone can help it would be appreciated, as i mentioned above the mot is 1st thing tomorrow.
Thanks in advance
Mark
Post #433526 Sun Aug 17 2014 6:07pm
Disco_Mikey
U0073 is an odd fault code. Just appears (seemingly) at random. Can be ignored and cleared Thumbs Up
Drivers frontal stage 1 is a loose connection in the drivers airbag or clock spring. Take the airbag out, have a fiddle with the wiring, and the light generally goes out Thumbs Up
Post #433542 Sun Aug 17 2014 8:45pm
squizzel
Thanks, but whats the clock spring?
I appreciate your help, i will have to hope it doesnt show in the morning, then have a look at it after the test.
Mark
Post #433550 Sun Aug 17 2014 9:51pm
squizzel
Not to worry i found it, the clock spring is the rotary coupler.
Thanks again
Mark
Post #433551 Sun Aug 17 2014 9:53pm
squizzel
Just looked and there was a recall over this, and dads car falls into the right chassis number. So there may be a call to landrover to see if its been done. If not they have themselves a job.
Post #433552 Sun Aug 17 2014 10:14pm
