Home > General > steering wheel shudder
scott1963
Hi.
I have a rr sport.i have changed the front and rear discs and pads anti roll bar arc bushes.and balanced the wheels.
I have had both the bottom front arms checked over as they were replaced 9 months ago little play on drivers side one good on the other side.
but I still have this vibration when I apply the brake coming through the steering.
thinking it might be the callipers I have the brembo system.or the alloys.
any help would be greatfull.
Post #433355 Sat Aug 16 2014 11:29am
Track rod ends? Anti roll bar drop links? 2012 SDV6 - it's missing a couple of cylinders
Post #433363 Sat Aug 16 2014 2:35pm
Paddi
Hi, you didn't say if the shudder was present before the disc and pad change. It is possible to replace the discs and trap a tiny bit of rust or dirt between the hub and disc so the disc runout is excessive. Everything will seem fine for a few hundred miles perhaps then the shudder starts. If this is the problem then the discs are damaged and will need replacing (check the runout during fitting). If you had the shudder both before and after new discs then it could be a damaged hub causing the excessive runout. Other possibilities are worn components in the steering or suspension so a full check might be worth a try. 2008 MY Java Black TDV8 HSE
Post #433365 Sat Aug 16 2014 2:37pm
Camelrock
Just had the same thing, I changed discs and pads all round, used Brmbo parts. 3000 miles later the shudder came back. Just changed the front discs again under warranty (I hope) and the problem has gone away. Will see what happens after another 3000.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #433367 Sat Aug 16 2014 3:32pm
Bob.
scott1963 wrote:
Hi.
..................I have the brembo system.............
Your icon says you have a TdV6 which would not originally have had a Brembo system. If Brembo callipers have been retrofitted they should have anti resonance (vibration) dampers fitted (rectangular chunks of steel bolted inboard to top and bottom of callipers). If Brembos from something else - say a FFRR - have been used, these will be missing as these are specific to the RRS.
Post #433385 Sat Aug 16 2014 9:03pm
hunter
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Are your wheels standard? if not....try a set of spigots....solved my problem..any alloy wheel place will have them and its a cheap fix...... Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #433412 Sun Aug 17 2014 6:09am
Disco_Mikey
Bob. wrote:
scott1963 wrote:
Hi.
The TDV6 did come with Brembo calipers, on models equipped with ARC/Dynamic Response
FFRR calipers will not fit an RRS
If you have a wobble under braking, then it is more than likely warped discs. What brand of discs did you use?
If it is under normal driving, then probably wheel balance
Post #433416 Sun Aug 17 2014 7:08am
Bob.
Embarassed
I'll go back to sleep.
Post #433464 Sun Aug 17 2014 8:57am
scott1963
the front discs I put on are padgid discs and pads.and were only fitted two months ago.yes I have the brembo callipers fitted and have the two small blocks of metal on top.
would it be better if I removed them and took them back or take them off and do what I never done clean the face.
surely the discs cant be warped in two months.
just had new anti roll bar bushes replaced everything was ok.went and got the rr front wheel balanced after the vibration was more noticeable when applying the brake.
Post #433512 Sun Aug 17 2014 4:12pm
hunter
Scott...really...all the symptoms are what i had...its easy to try my fix and very cheap compared to going round the houses.... Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #433516 Sun Aug 17 2014 4:32pm
scott1963
hi ok will try the spigots.see if that works.
Post #433583 Mon Aug 18 2014 10:53am
hunter
Its better to try a £25 fix first than spend hundreds needlessly.............. Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #433584 Mon Aug 18 2014 11:05am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Had this on my MY12....
Even more baffling was the brakes sticking.... but only when I was at sea level...
When I was in the mountains at altitude they functioned perfectly.
Thread below also offers some interesting solutions
http://www.rrsport.co.uk/forum/topic35819.html 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #434735 Sun Aug 31 2014 6:31pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
I get a vibration on the wheel when driving sometimes, not all the time though. Just assumed it was part of the car. Should I be looking for something more? I've it under warranty now, so best find it before it expires.
Post #435551 Sun Sep 07 2014 4:56pm
andman
Absolutely... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #435561 Sun Sep 07 2014 6:47pm
