Home > General > detatchable tow bar key issue |
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 |
Hi make sure you pull out and turn the round knob on the side where there key goes in. Do this before you insert the tow at into the recess. When it is in the round knob should spring back round allowing you to remove the key. |
Thu Aug 14 2014 7:55am |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
hi nigel, the green knob is working fine its more of a key issue, the lock wont work with either key and i can put them in/out of the lock no matter what position the green knob is in |
Thu Aug 14 2014 11:42pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Give it a good soaking of WD40 or GT85 over night and then try ON THE WAY: BMW F21 M140i
Fri Aug 15 2014 10:20am |
