Home > Wheels & Tyres > Wheel and tyre spec |
Diameter: 20"
Thu Apr 24 2014 9:41am |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
thank you |
Thu Apr 24 2014 9:48am |
Michael calvert Member Since: 09 Feb 2014 Location: near leeds Posts: 219 |
Anyone know how small you can go?
Thu Apr 24 2014 6:26pm |
mcdziubek Member Since: 14 Aug 2014 Location: Cippenham Posts: 3 |
If you still looking for mt tyres then you can buy mickey thopmson baja mtz in a size 305.55.20 they will fill wheelwell by extra 60mm check if you have enough clearance for that with your hand when at standard height.
Thu Aug 14 2014 3:06am |
HAWKE Styling Member Since: 05 Nov 2013 Location: Luton, Bedfordshire, LU3 3HP Posts: 59 |
Hey guys - this might be of use for selecting tyres and changing wheel sizes.
Thu Aug 14 2014 1:12pm |
Bungleaio Member Since: 06 Apr 2014 Location: Leicester Posts: 172 |
I know they are proper heavy! I took one off recently and I've never held a wheel so heavy. |
Thu Aug 14 2014 1:33pm |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 |
Hawke on your update list image....I note that it states maximum offset for a 10j 22" rim is 47. I was checking out a rim/tyre package with the following dimensions.....would I have a problem fitting these to a 2.7 TDV6 HSE 06 ? I have no clue with regard to alloy wheels and would value your opinion here....(or the opinion of anyone else who can tell me if the following are ok for my RRS).
Thu Aug 14 2014 3:10pm |
@mad-dafty..
Fri Aug 15 2014 10:59am |
Thanks for your input Hawke.......Not sure what I should do now......don't really want to take a chance on having these delivered only to find they cause a problem.
Fri Aug 15 2014 6:08pm |
