Home > Technical > Noisy Diff? |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
Also, any thoughts on renewing the gearbox oil, though I understand this is not easy so maybe should leave alone for now. I don't have any gearbox problems currently but want to keep the car running for at least another 5 years |
Sun Aug 10 2014 4:42pm |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
change the gearbox oil and filter if you want to keep the car for another 5 years. but indeed that is a tidious job as the access is very limited.
Mon Aug 11 2014 2:46pm |
OK so now I'm confused......Spoke to two different Land Rover Specialist Garages and described the same fault. One said 'sounds like the prop bearing, had to change loads, hardly ever had a problem with the Diff), then spoke to another who said 'almost certainly the diff......done loads recently, about £400 to rebuild). Anyone got any ideas of how to definitively work out which is at fault? |
Tue Aug 12 2014 3:06pm |
So, took the car for a drive with an experienced mechanic in the passenger seat. He was '95%' certain that the noise was coming from the nearside front bearing. I was pleased with that diagnosis as it cost less to replace the bearing than have the diff repaired, and others have spent money on diffs to find it was actually the bearing. I replaced the bearing (hub assembly), but alas, rumbling still there |
Wed Aug 20 2014 7:09am |
Update: Took my car to IAWA 4x4 in Wellingborough, as from a telephone conversation they appeared to know what they were talking about. Left them the car at 08.30, picked back up at 15.30 and the problem was solved. Front Diff was removed, re-conditioned with new bearings etc and re-fitted, total cost £430. Big thanks to these guys for their professionalism and reasonable charges. |
Thu Nov 27 2014 3:47pm |
Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91 |
It's nice to hear some good news |
Thu Nov 27 2014 4:22pm |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
Glad you got it sorted tony |
Thu Nov 27 2014 5:52pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The chap who runs IAWA4x4 is a member of the Northants 4x4 forum and well regarded thereabouts. I used him to do a gearbox fluid and filter change a couple of years ago based on recommendations. Found him to be as described. Oh, and there's an American-style diner on the industrial estate that serves a reasonable breakfast! 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 27 2014 6:25pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Good recomendation here. I'll keep note! I'm not Fat. RRS TDV6 HST. |
Thu Jan 15 2015 12:36pm |
