Home > Maintenance & Modifications > megaflush
gogsy1956
megaflush
Anyone know of a garage not too far from the Newcastle area that can carry out the autobox flush. I know of one in York but a bit closer to "the toon" would be nice 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #431442 Thu Jul 24 2014 8:17am
Try posting in this thread. DM might get down as far as you or at least arrange some mutually convenient mid point meeting. Thumbs Up
http://www.rrsport.co.uk/forum/topic34803.html 2012 SDV6 - it's missing a couple of cylinders
Post #431470 Thu Jul 24 2014 11:58am
chilly
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
i don't know for defo mate but northeastern 4x4 in middlesbrough might do and its easy to get to only 2 min off the A19 think they have a website or at least there number will come up with google
had good experiences in the past with them and there service only the dead truely know peace,
Bootneck its not a job its a way of life!
Post #431474 Thu Jul 24 2014 12:48pm
gogsy1956
ok guy's, thanks for the suggestions 2010 RRS, TDV8
22" overfinch
Post #431508 Thu Jul 24 2014 6:15pm
TDV8Mat
England 2013 Range Rover Sport Supercharged HSE Santorini Black
Have you got details for the place at York that does it please?
Post #431861 Tue Jul 29 2014 1:10pm
Gargy
England 2009 Range Rover Sport TDV8 HSE Santorini Black
Being a bit of a newbie around here.
What is a 'megaflush', and what's the point of it ?
Ta.
Post #431865 Tue Jul 29 2014 1:52pm
Megaflush is the trade name for a method of changing all of the fluid in your automatic gearbox. Basically the system pumps out the old fluid and simultaneously pumps in new fluid.
It's done because the usual method of draining via the drain point only changes about 40% of the old fluid.
LR claim the gearbox is sealed for life (150,000 miles) but ZF ,who manufacture the gearbox, recommend fluid change at 70,000 - 80,000 miles. 2012 SDV6 - it's missing a couple of cylinders
Post #431874 Tue Jul 29 2014 3:32pm
gogsy1956
Hi Mat
The place is called Quattro auto care and is located in Riccall..... Around the Selby area I believe. I think the price was around the �260 mark. 2010 RRS, TDV8
22" overfinch
Post #431876 Tue Jul 29 2014 3:49pm
TDV8Mat
Nice one, thanks for that Thumbs Up
Post #431933 Wed Jul 30 2014 9:39am
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Could we not make a pump? Was thinking of an elec hydraulic pump, 2 catch tanks equal to the amount of fluid in the box. Then a hose to the inlet and drain?
What you think?
Post #432379 Tue Aug 05 2014 12:26pm
gogsy1956
I think their may be a bit more to these machines than just sucking out the old oil and pumping in new. Have one look on U tube for Winns flushing machine or transverse, there is video of one in action. Apparently there are not a lot of these in the UK and being quite a clever bit of kit they are more of a recovery machine rather than a straight forward pump. I believe they measure what comes out and only the same amount of oil is replaced. It's not the sort of thing I would like to have a diy go at and get it wrong! 2010 RRS, TDV8
22" overfinch
Post #432437 Tue Aug 05 2014 9:51pm
looneyfitter
Thanks mate I'll have a look
Post #432439 Tue Aug 05 2014 10:55pm
Disco_Mikey
The machine is connected into the cooler pipes, and uses the oil pump inside the gearbox to push the old oil out. The machine measures the quantity of oil removed, and automatically replaces it with new oil, from a separate container, so the new and old oil doesn't mix
There is a little viewing window, which allows you to see the condition of the old oil, and when completed, the new oil too. This car was not too bad, I have seen some boxes push out a thick brown sludge Shocked
The machine is rather expensive, hence why there are not many of these machines in the UK.
Post #432445 Wed Aug 06 2014 5:56am
looneyfitter
How much is a flush DM?
Post #432607 Thu Aug 07 2014 11:29pm
Disco_Mikey
Depends how far I have to travel, and how many cars need done in the same area.
If it is local to me, and I don't have to spend hours travelling, �275 inc VAT
If it is further afield, it depends on distance, however this can be offset if there are 3 or 4 cars needing done in the area Thumbs Up
Post #432619 Fri Aug 08 2014 6:31am
