![]() | Home > General > STOLEN |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
You could go all James Bond with this modification and have a pop out panel with a hidden switch. |
Salmon&permit Member Since: 02 Aug 2014 Location: London & everywhere Posts: 36 ![]() ![]() |
Thanks for all the thoughts and feedback. No sign of car - and not expecting any. Will contemplate various cut off options, but suspect the best way forward will be along 'physical' protection line.....a dirty great retractable bollard in front of the car. Simple, not too expensive and not relying on not-so-clever electronics. Might even go for the old yellow steering clamp too....belt and braces, locking the stable door after the first horse has bolted, but hoping it will stop others going astray! |
Yeah drop posts are good, I've got one. |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
Has there been any indication on how they did it?
Driven off - I saw it go after I heard them start it up. It has been suggested that the locking signal was 'blocked' when I locked it earlier in the evening. So, worth double checking that car actually locks when you instruct it to do so! Insurance company say there are some very professional and technolgy enabled eastern europeans knocking around, stealing to order and shipping out very quickly. Takes them less than a few minutes to get in and drive off..........and they know where to look in terms of where the typical tracking device is located. Hope this helps others avoid what has happended to me..... |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Not everyone's cup of tea but I interrupted and re-routed the fuse lead (back of fusebox) for the fuel pump in a Subaru Impreza Turbo, to a hidden switch. No way that baby going to start unless you knew where the switch was... |
