Home > Maintenance & Modifications > diy changing air con condenser, |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4384 |
Diesel models are 1.5-2 hours, petrol models take longer |
Thu Jul 31 2014 8:32pm |
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 |
I intend to take photos and post them when done. Along with any detail which may help others in future |
Thu Jul 31 2014 9:10pm |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
that sounds more like it mickey |
Thu Jul 31 2014 9:15pm |
As opposed to this? http://www.disco3.co.uk/forum/topic98740.html |
Thu Jul 31 2014 9:37pm |
At least you got it changed. How long did it take you . I changed bottom ball joint on mine today |
Sat Aug 02 2014 7:04pm |
from start to finish just over 4 hours if I had to do it again I think I could do it in 2 hours, the main prob is getting the seized bolt out bottom of the bumper which all snapped off, had to drill and tap to 8 mm from 6mm, just the parking sensor pro
Sat Aug 02 2014 7:24pm |
Hi can anyone tell me what the grey connector highlighted yellow is please,
Sat Aug 02 2014 8:07pm |
TPMS antenna connector |
Sat Aug 02 2014 9:12pm |
Thanks. Do you know what prob could be with parking sensor. Was all working perfect before removing bumper. I connected all leads |
Sat Aug 02 2014 9:19pm |
Same happened with my D3 when I had the body off.
Sat Aug 02 2014 9:45pm |
hi guys, i bet you all fed up with me now but one final question, can you tell me what this connector is and where should it locate,
Sun Aug 03 2014 9:57am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8953 |
Isn't that the connector for the (optional) ACC? 2012 SDV6 - it's missing a couple of cylinders
Sun Aug 03 2014 10:17am |
It's also there on D3's, which never had the option of ACC.
Sun Aug 03 2014 10:52am |
What's ACC. ??? |
Sun Aug 03 2014 11:02am |
