Home > Off Topic > Renting out residential property |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Don't forget you have to be careful with capital gains tax as you are only able to have your main residence exempt from CGT. If you make it fit by saying you have split up etc etc you may lose the CGT exemption on your main residence which is likely to have a larger gain and shoot yourself in the foot. There is also a allowance that you can deduct before you calculate CGT. If you purchase in joint names (you and your partner for example) you get double the allowance.
Fri Jul 25 2014 10:16pm |
You can order a free book from HMRC that gives you all the info but its quite heavy reading. Join your local Landlords Association or the National Landlords Association for more info. Give me a shout if there is anything I can help you with MY16 AUTOBIOGRAPHY Indus silver with some toys
Sat Jul 26 2014 11:10pm |
