![]() | Home > Maintenance & Modifications > Key Fob - Falling to pieces! |
TrevG Member Since: 14 Aug 2012 Location: Kent Posts: 48 ![]() ![]() ![]() |
I paid �160.00 for the key plus �26 for programming last year from an indie..... |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Can you not just buy one off ebay and swap the internals over? 2014 L405 SDV8 RR Autobiography |
Cooperm28 Member Since: 24 Jun 2014 Location: Essex Posts: 46 ![]() ![]() ![]() |
I've only had the car a month or so, its a 2010 RRS from Lookers so wouldnt this sort of thing be covered under the used car warranty or would they sweep it under the "wear and tear" cat!
Neil,C Member Since: 20 Jun 2014 Location: Runcorn Posts: 22 ![]() ![]() ![]() |
wemeadows Member Since: 22 Jul 2013 Location: Washington State Posts: 21 ![]() ![]() ![]() |
The rubber on my key fob started peeling away within a few months of getting the new vehicle. LR replaced it under warranty, although it took them a full day to program the new fob. 2013 RRS HSE Lux, Fuji White w/Silver Pkg, 5.0 V8
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
You can buy housing only (from dealer ) for peanuts |
Yes, a few helpful PM's from JPR 1 and i managed to pick up a genuine housing from Hardwoods ebay store for �4.99!
ss30 Member Since: 25 Apr 2014 Location: Oxford Posts: 19 ![]() ![]() ![]() |
@Cooperm28
Best �4.99 I've spent in a while. A bit of ummm and ahhhh'n later i found a workshop PDF online which basically walks you through pulling the old key apart! 5 minutes later and with the use of one flathead screwdriver we are looking like new and working fine! NOTE - i was worried about removing the battery and needing it re programmed but its says at the bottom of the PDF - IDS / SDD is not required to program the key at the end of this process. |
Glad you got it sorted. |
Michael calvert Member Since: 09 Feb 2014 Location: near leeds Posts: 219 ![]() ![]() ![]() |
Link to eBay ad would be good for us all.... |
The EBay link is in the Marketplace Forum under the sub section "EBay and Bargain spots" for anyone wanting to check them out. |
dannyccmc Member Since: 15 Nov 2011 Location: Houston, Texas Posts: 10 ![]() ![]() |
Would you mind posting the workshop pdf? 2011 RRS Supercharged, Santorini Black on Brown/Tan, pretty perfect as is 2008 RRS HSE Lux (sold), Alaska white on Ivory/Ebony, Supercharged front and side grill's, 20" genuine stormer wheels, Supercharged front Brembo brake retrofit, Supercharged exhaust tips retrofit, 2010+ tail lights retrofit, Color coded mirror caps, Nappa leather steering wheel retrofit. |
The following web address will bring you to the PDF in webpage format.
