![]() | Home > Maintenance & Modifications > Changing Front Diff - advice? |
Had my front diff changed by a local specialist and no problems since. It isn't necessary to take the engine out. Just pull the front driveshafts and then everything just unbolts I think. I asked them to clean out the tube (not the correct term but it'll do!) That the driveshafts run in to get rid of any metal particles that might have come out of the diff where it had worn. You don't want any bits of old diff damaging anything. 2008 MY Java Black TDV8 HSE
Bungleaio Member Since: 06 Apr 2014 Location: Leicester Posts: 172 ![]() ![]() |
Not sure which part of the midlands you are in but if you wanted to speak to a specialist and get a quote from them I've used http://www.armsonae.co.uk/ and I will be using him for all other stuff I need. |
Stiggy Member Since: 08 Nov 2008 Location: Midlands Posts: 5 ![]() ![]() ![]() |
Thanks both for your posts.
