Home > Technical > Suspension problem
Page 5 of 9 <123456789>
chesterfield
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Ill add my name to the list of people with suspension faults.
MY11 TDV6, 8 months old 7k on the clock, never been off road (yet).
"only normal height available" & "forward alert not available".
The wife had noted that in the last few months there has been an intermittent droning sound coming from the left of the car. While driving through town it comes on for a few seconds then goes off for a few seconds, then back on again. Thinking about it, could this be the compressor trying to keep up with a leak in the system and therefor have led to premature wear?
Im going to contact the dealrs today and get them to have a look at it anyway.
I had hoped that after my last debacle with JLR and the pathetic XF I had, that I was unlucky and had just bought a lemon. Now Im wondering if thats all they can build Sad Confused RRS 3.0D HSE 11MY - Fuji White, a few extras.
Post #327541 Tue Jan 10 2012 10:30am
chesterfield
Car now booked in for next Wednesday to have a new compressor and relay fitted. So it takes 2 weeks to get a compressor from JLR and then the dealership cant book the car in to even be seen for another week.
Is this seriously how long things take to get fixed under warranty with JLR? Three weeks with a faulty car? RRS 3.0D HSE 11MY - Fuji White, a few extras.
Post #329600 Thu Jan 26 2012 11:17am
justin ashbourn
Katrina, mine is in the garage for the same 'lean when cornering' light orange. They have just phoned to say it won't be coming back yet as its a big job, they have to access the valve gear and test the appropriate part. I think they are setting me up for a big bill and would love to find out how you get on, or if anyone else knows anything about this fault. I have to say in general my first edition supercharged has been very reliable up to now with no real problems and this is the first light I have seen!!
Post #332487 Tue Feb 14 2012 6:48pm
Katrina999
United Kingdom 2007 Range Rover Sport TDV6 HSE Siberian Silver
orange light
Hi Justin
Mine was apparently a valve which was covered under the warrantly thankfully so don't know how much it would have cost had it not been. But I now have a droning sound think it's the air compressor which has an issue Grrrrrr husband wanted to get rid off the car but hopefully he will calm down ours has been nothing but trouble from day one but I did take the extended warranty out which has paid for itself three times over to date. x Katrina
Post #332492 Tue Feb 14 2012 8:24pm
justin ashbourn
Katrina thanks for the reply, I hope your problems stop soon as these are such great cars to drive, good luck. x
Post #332529 Wed Feb 15 2012 9:44am
Mike waldie
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi guys, think I'm beginning to have suspension problems. The dash all lights up, goes into safe mode and says suspension lowered etc. turn off and back on and all fine. Can go weeks with no problem or can go again 2 minutes later. There's times as well I've thought the passenger side rear has dropped all of a sudden then rights it self!!!! Is there anywhere near Liverpool you could recommend me taking it without getting ripped off as well. Thanks. Mike
Post #343488 Sun May 13 2012 12:12pm
cobbler2u
England 2005 Range Rover Sport TDV6 HSE Stornoway Grey
Have same problem.
Oranage light on some times. Normal height only comes on on dash board. Some times turning ignition on and of clears it. Lately come on as im driving.
Think i need new compressor
Im running standard 20" wheels
Post #379402 Tue Apr 02 2013 12:32am
Coxylad
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Katrina999 wrote:
Hi
When they brought the car back to the waiting area they informed me that the warning light might come on as the whole Steering rack had been replaced due to a faulty seal they felt they needed to changed the part in full.
There was no code that I saw but the light did come on minutes after I drove it. they said that all that was required was a reset by Landrover ?? After reading for a few hours on this very informative forum I'm now panicking that they are not telling me the truth and they also mentioned that the part they removed had not been a genuine part but reconditioned steering rack the car is an 07 plate with only 35,000 on the clock .
I'm not liking the sound of all this.
I have just bought my RRS 2.7tdv6 2007 last month it has 37.000 miles on the clock
Is this when all the problems start, I really hope not. I have only done 90 miles in it sice IV had it as I'm away working in Egypt so I'm hoping for trouble free motoring when I get home
Should you raise and lower the suspension on a regular basis to keep all the parts active or should you just leave them alone as I only plan on doing normal road use.
Thanks 2007 RANGE ROVER SPORT 2.7 TDV6 HSE in silver
Post #389642 Tue Jul 23 2013 12:41am
Coxylad
Katrina999 wrote:
Hi
Post #389643 Tue Jul 23 2013 12:45am
jack.bauer
Thanks
i was told to lower it overnight as it saves battery.
thats made things worse and now i need a new compressor too.
apparently regularly raising/lowering turns the compressor into an old man basically. 07 TDV8 + BAS map
Post #391472 Mon Aug 12 2013 12:22am
Andyred90
Had this problem with a D3 and it turned out to be camber angle sensor. Reset and never any further problem.
Post #394826 Thu Sep 12 2013 10:24pm
Andyred90
Post #394827 Thu Sep 12 2013 10:24pm
overfinchred
I have a 2008 model that has done this twice and then I turn off and back on again and fault clears? “One good thing about music, when it hits you, you feel no pain.”
Current RRS Overfinch TDV8, Nissan Skyline R34 GTT, 1958 VW Splitscreen camper, 1961 VW Splitscreen Double cab pickup( now gone), Fiat 500
Gone -BMW X5 and X6, Jaguar XF, Chrysler 300c, Nissan Figaro, Nisan 350z,BMW 3 series, Merc 220d, various Fords, Mini Cooper, 3 old shape mini's, Ford Capri
Post #395089 Sun Sep 15 2013 8:15pm
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
For what it's worth, mine came up with the Amber Suspension Warning Light, which was intermittent on when it came on, i.e - 5 minutes into drive, 15 minutes, 40 minutes!! Suspension was slow to raise, sometimes didn't at all, sometimes raised and never went down - it basically did what it wanted to do!!
My 4x4 Specialist has diagnosed that a new compressor is required and my warranty company are covering the cost.
The compressors apparently have had lots of issues and are now obsolete, so a new type of compressor is being put on mine, to the tune of circa £500 + labour. Fingers crossed that should do the job
Post #429942 Wed Jul 09 2014 5:33pm
l
Spain 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Suspension
Incredible but true I have found a mechanic two miles away from my house who knows how to repair compressors!!! He took mine apart cleaned it out changed seals and it is working correctly. RRS TDV6 HSE BUCKINGHAM BLUE BLACK LEATHER INTERIOR RHODIUM TASMOD SILLS PARROT 3000 EVOLUTION WHITE SIDE REPEATERS RRPORT.CO.UK BROLLY & STICKER
HOW GOOD IS THIS CAR!!!!
8 YEARS AND STILL GETTING LOOKS
Post #431357 Wed Jul 23 2014 1:16pm
