![]() | Home > Technical > Main beam activation |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
In simple terms when the indicator stalk is in the middle position this is normally dipped beam and pushing the stalk forward put main beam on but my car is reversed dipped beam is on in the forward position and not central
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
Sounds like the auto dimming is on. The car will activate the main beam when it doesn't detect any headlights or taillights ahead. To then go manually to low beam your have to move the stalk back (to normal flash position).
Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95 ![]() ![]() ![]() |
I had exactly the same thing happen on my 2005 HSE after I got shunted by the car behind. I had the main beam 'on' position reversed but also the main beam couldn't be 'flashed' - seems the innards of the stalk were shot and the spring had gone. Once replaced, it was back to normal operation as you described. I managed to get the newer decal stalks from one of the other forum members here. Ask and you might be lucky too.
Thanks for the info
My indicator stalk is part 500120
That's the p/n that I used for my replacement: XPC500100 |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Got one spare if needed ![]() ![]() 17MY Autobiography Dynamic - Corris Grey - WOW. 14MY Autobiography Dynamic - SDV6 - Fuji White ![]() 12MY Autobiography - SDV6 - Santorini Black - Dual View - Rear Entertainment - Sunroof. 12MY Autobiography - SDV6 - Orkney Grey - awesome ;( 2005 Java Black - 4.2 V8 Supercharged First Edition- will never be forgotten ;( |
Thanks for the offer
