Home > General > turbo pipes /actuator rod |
Alex C Member Since: 09 Jun 2013 Location: Southampton Posts: 146 |
Easy to check.
Sun Jul 20 2014 8:41pm |
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 |
Alex could you tell me the symptoms you had please what sort of noise alerted you to this |
Sun Jul 20 2014 8:44pm |
Stuck actuator bought on limp mode, yellow engine light and no power. Freed itself for a time but then kept sticking, quite disconcerting when it goes into limp mode in lane 3 of the motorway and drops to idle power! Pull over turn off then on again sorted it. I searched on here and read up about the WD40 trick, all shoved.
Sun Jul 20 2014 10:06pm |
Hi Alex its more a find the fault before it happens really i am getting a small rattle when under load so I'm going through a few possibilities |
Mon Jul 21 2014 6:45pm |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
I've been thinking about this for a while now but if the actuator rods can stick and cause problems does it not make sense to apply something like WD40 once a month or so to try to prevent them sticking? It would be a pain to do but less of a pain than having to free off a sticking actuiator or worse still, to actually break down. Any ideas anyone? |
Mon Jul 21 2014 8:14pm |
Not sure about a rattle, heat shield maybe?? Would wait for one of the more knowledgable guys to come along on that one. If you are going down the preventative route I would take a look at the intercooler pipes and check their condition, I replaced the second one at the same time as a preventative measure.
Mon Jul 21 2014 8:50pm |
