Home > Technical > steering wheel vibrating |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 |
Possibly, don't discount the simple remedies that you'd normally think about on an older car. I had to have a full 4 wheel alignment done on mine after 1 Week! L319 D4 HSE
Mon Oct 31 2005 7:30am |
Esoteric Member Since: 01 Oct 2005 Location: Northern VA Posts: 21 |
Usually a vibrations is caused by a wheel out of balance. Sometimes they are not balanced correctly from the start and other times some of the weights can fall off throwing it out of balance. |
Fri Nov 04 2005 2:18am |
Have you taken it through any sticky mud? If so put the steering on full lock one way and then look in the backs of the wheels for lumps of mud stuck inside the rims these act like unbalancing weights. Turn the wheels to full opposite lock and do the same thing again. This was what caused mine to be wobbling.................. but then I had been offroading in sticky mud. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Nov 04 2005 9:18am |
Quasimoto Member Since: 27 Jul 2005 Location: Middleburg, VA Posts: 34 |
I sometimes notice vibration, but it appears temporary. I attribute it to cold tires, though there are many theories...
Wed Nov 09 2005 2:45am |
LeePeto Member Since: 01 Nov 2005 Location: London Posts: 16 |
Get the wheels checked, hopefully will fix it. |
Thu Nov 17 2005 11:49am |
On my last car cold tyres would cause slight vibrations for a mile or so. L319 D4 HSE
Thu Nov 17 2005 2:40pm |
Persuader Member Since: 21 Oct 2005 Location: Wakefield Posts: 88 |
Sounds to be definitely the wheel balancing. I'm sure that it's just that a wheel balance weight has come off. Get all fours wheels balanced and that should fix it. 2013 New Range Rover Sport HSE SDV6
Sat Nov 19 2005 10:20am |
BIG BAD RANGE Member Since: 24 Nov 2005 Location: KENT Posts: 64 |
I HAVE JUST HAD DELIVERED A RANGE SUPERCHARGE AND NOTICED A WHEEL VIBRATION ABOUT 70MPH HAD ALL THE WHEELS RE BALANCED STILL THERE !!! THEN TOOK THE CAR TO ELITE IN ESSEX TO CARRY OUT A 4 WHEEL ALINEMENT CAR IS PERFECT NOW WELL WORTH CHECKING. |
Thu Nov 24 2005 10:33pm |
