Home > Technical > U0402 CODE!!!
DEBENJE
United States 2011 Range Rover Sport TDV8 Bali Blue
U0402 CODE!!!
I HAVE A 2011 RANGE ROVER SPORT WITH THIS CODE U0402 INVALID DATA RECEIVED FROM TRASMISSION CONTROL MODULES. DOES ANYONE KNOWS HOW TO SOLVE THIS PROBLEM, I TOOK IT TO THE DEALER AND THEY STIL CANT FIND A SOLUTION. THANKS
Post #430260 Sat Jul 12 2014 3:04pm
The full DTC code has a further two digits to it. These would be necessary to try to pin point possible issues. I'm amazed that the dealership weren't able to get closer to the problem. 2012 SDV6 - it's missing a couple of cylinders
Post #430273 Sat Jul 12 2014 6:21pm
Disco_Mikey
A U code is a comms error, which can generally be ignored, unless you are having specific issues with that network.
They can also be logged due to a "cascade" fault
You need the whole car scanned for "P" and "C" codes
Post #430278 Sat Jul 12 2014 7:18pm
