Home > General > rr sport suspension
stekar
rr sport suspension
my suspension is very hard on roads a rr sport should be good at. un even roads, speedbumps etc.
the ride becomes very uncomf at bumpy roads.
is it a suspension software thing or?
no knocking sounds or anything, just u get tossed around alot.....
not cool.
pleased to hear
Post #429889 Wed Jul 09 2014 11:11am
speedy2009
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
What spec is your car
Post #429895 Wed Jul 09 2014 11:31am
stekar
06 rr sport but been so for a while unf
Post #429897 Wed Jul 09 2014 11:37am
Possibly the corner valves need changing. There are three blocks: one for each axle and one for the reservoir. They're not expensive. 2012 SDV6 - it's missing a couple of cylinders
Post #429917 Wed Jul 09 2014 1:19pm
Peanut
Intriguing! Mine is also a bit bumpy - on a speedhump road in Oadby my lad's Fiesta handles them better...
Why exactly would these blocks cuse the problem? My Air suspension seems to be OK otherwise - it's quick to pump up and never goes down when parked.
Post #429924 Wed Jul 09 2014 2:14pm
I seem to remember some mention of it on Disco3 when I was researching an issue. Some people said that fitting new valve blocks helped soften their suspension. 2012 SDV6 - it's missing a couple of cylinders
Post #429951 Wed Jul 09 2014 5:51pm
simple1
Suspension is usually quite compliant unless pump or ride heights are at fault. Worth getting these checked first then look at valve blocks. Have done lots of experimenting with FF to get a combination of ride quality and lower centre of gravity/cosmetic look. Even if you drop the car 10mm from standard by fudge/computer set, the ride becomes harsh. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #430011 Thu Jul 10 2014 6:58am
