Home > In Car Electronics > Weird Electronics
Simon73
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Weird Electronics
Seem to have intermittent weird electronic issues. Most days I get into the car the nearside mirror is down and I have to move it up. Occasionally its the offside. Two weeks ago I was driving and it said HDC problem when cornering and so lowered all the suspension while I was doing 50mph there were lights everywhere then I turned it off and it started up no problems. A week ago while doing 60mph all the electronics went off, power went the dials all dropped and I started to panic, a second later it all fired up again and away we went. Took it to the dealer who said there were no faults showing but did a hard reset to cure the wing mirror issue. It hasn't it did it again today and then on top of that the sat nag screen went blank and there was no sound through the stereo. Then I tried the car after leaving it off for an hour and bingo its all back on again. Is this likely to be one issue causing this or just a load of different ones. On top of needing two new tyres, new pads, discs and a door latch this week this week all in all I'm starting to get a bit fed up Smile
Post #429396 Sat Jul 05 2014 4:35pm
PHinett
I'm by far not qualified to answer this, but after reading through these forums it sounds like it might be a battery issue...maybe try charging it? 57 Reg TDV8 - Java Black - Privacy Glass - Side Steps Smile
Post #429400 Sat Jul 05 2014 7:04pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
It may be the battery connections are not tight enough- try cleaning your battery terminals and making sure you've got a good connection.
The mirror thing may be connected to the memory settings of your seats- or your lazy entry settings.
Post #429461 Sun Jul 06 2014 10:55am
