Home > Wheels & Tyres > Will these wheels fit my 59 plate Sport?
Mahrenholz
2010 Range Rover Sport TDV8 HSE Santorini Black
Hi guys
Looking at buying these for my 59 plate RRS
http://www.ebay.co.uk/itm/111398198586?_tr...EBIDX%3AIT
The model number is LR 027544
I spoke to Land Rover and they said these were listed under newer models only so weren't sure. Any help much appreciated. The seller thinks they will fit, is there any chance they "fit" on, but don't function properly (have heard the term offset branded about on similar threads)
Am replacing a set of 22" wheels because they keep cracking from pot holes Sad
Post #429257 Thu Jul 03 2014 8:29pm
PEACHY
Welcome to the forum - yes they will fit Thumbs Up 16MY Estoril Blue SVR.............
Post #429258 Thu Jul 03 2014 8:36pm
Mahrenholz
Ok many thanks
1 follow up question, the tyre pressure monitoring hasn't worked since I had the car as it's not compatible with the 22" wheels. Do I need to do anything to get it to work once they are swapped for 20" wheels or will it work automatically. Have read somewhere before about a metal valve you need?
Also, will the wheel nuts currently used for the 22" wheels work for the new ones?
Post #429261 Thu Jul 03 2014 8:39pm
PEACHY
Wheel nuts should go straight on - you need the TPMS valves fitted then they may need calibrating to the main sensor - sorry I can't give you a definite answer Rolling Eyes 16MY Estoril Blue SVR.............
Post #429262 Thu Jul 03 2014 8:42pm
Mahrenholz
Mahrenholz wrote:
Ok many thanks
OK - will ask the dealer when I take it in for a service - thanks again
Post #429263 Thu Jul 03 2014 8:43pm
PEACHY
Use the search function on the top banner - 'TPMS' brings up lots of useful info Thumbs Up 16MY Estoril Blue SVR.............
Post #429264 Thu Jul 03 2014 8:49pm
