Home > Wheels & Tyres > changing tire size
gdaniels
changing tire size
I have a MY11 Supercharged, with 275/40R20's. The potholes in our roads have already cost me three tires. Can i change to 275/50R20"s ? If I do, dare i use my spare tire?
Post #422339 Fri Apr 25 2014 8:40pm
You could do that - you should be ok for size in the wheel arch when applying lock I run 255/55/19 which is only 20mm smaller than that in diameter and there appears to be enough room for a slightly larger tyre; you would need to heck carefully on full lock however.
You wouldn't want to use your spare for anything other than a short, slow drive in an emergency as there's a 7.5% difference in diameter so you risk annoying the transfer box and the DSC.
If you do want to go to 275/50/20 then buy a new spare tyre in that size too... 2012 SDV6 - it's missing a couple of cylinders
Post #422355 Fri Apr 25 2014 11:10pm
Marky B
2008 Range Rover Sport TDV8 HSE Java Black
Hi, can anyone tell me, can I change my wheels to disco 4 10 spoke 255 55 19 as I have brembo brakes
Post #429082 Tue Jul 01 2014 7:39pm
muddywheels
Milk Float Man
I would change to recommended size of 255 50 19. This will keep speedo and mechanical components happy. This will give the best ride and protection on rough roads Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #429094 Tue Jul 01 2014 8:57pm
