Home > Technical > wheel alignment issue
shadrack
so i had new bottom arms fitted i then took it to get a 4 wheel aligment, and anyway to me the camber is way way out i think but arnt sure, i dont remember having any camber on the front wheels before, what do you think its clearly visible, with the car in normal mode, it looks to me as if the camber adjustment bolts should be flipped 180 degrees to keep the same setting but pull the bottom arm in an inch to pull the wheel in at the bottom.
with a spirit level on the rears are straight plumb, the front run out 2 inch in the wheel height with the tops 2" further in than the bottom.
it drives fine and to be fair i had the alignment done about 2 months ago and just noticed the other day when i was looking at it.
Post #428513 Thu Jun 26 2014 4:34pm
hunter
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Looks different to mine i think Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #428521 Thu Jun 26 2014 5:18pm
