Home > General > Newbie , after some advice :-)
Bulls20042002
Hi guys
I'm in the market for a RRS and was after some advice ,
I'm looking at spending £15k-&£18k
I was wondering what I should look out for, common faults etc,
Should I be put off by 100k miles on some cars?
Which is the best Engine size to go for?
Thanks in advance for your help, Thumbs Up
Post #427314 Mon Jun 16 2014 1:06am
BKHK
Australia
Have a little go with the "search" function and you will find plenty to read. There is a "buying guide" on here which will help you. There are too many considerations to type in a simple post.
Don't even think about buying until you have had a good read on the site because you will know what to look for and what to run away from. Forewarned is forearmed. You will also probably get a better car and a better deal if you read for a week on here first.
Post #427315 Mon Jun 16 2014 1:47am
Alex C
2008 Range Rover Sport TDV8 HSE Java Black
Totally agree with BKHK, spend time reading up on here and get to know all the common 'features'! I bought a TDV8 this time last year without doing enough pre homework and all the things you will read about have happened, had I gone in with more prior knowledge I would have been looking for the problems.
Add a strong 1000 pounds on top of your purchase budget to cover running costs of things failing as unless you get a LR warranty, aftermarket warranties are not good enough to cover what goes wrong on these - mine has not paid out once even though it had top level cover - warranywise, will not be buying their product again!
Pay special attention to;
Suspension compressors and level of the car
Turbos, sticking actuators and split pipes
Door locks, rear doors and upper tailgate
Suspension bushes, any knocking noises under braking from slow speed
Service history - fuel filter change along with everything else is really important
Electric seats, move about due play in the mechanism, easy fix
Electronic handbrake - total pain, read up on this one, esp where the emergency release is hidden!
Battery, when was it last changed? Many problems are actually just symptoms of a failing battery as the car is so sensitive.
That is my list of 12 months worth of learning, many of them I have fixed myself after searching on this site, loads of really helpful owners on here who help out when things go wrong Smile
I love the car and when it is behaving it is fantastic. The engine is awesome and make long trips fly by, go for the TDV8, just go in eyes open!! TDV8 Java Black, Overfinch 22s
Post #427325 Mon Jun 16 2014 6:24am
Welcome to the site Bully Thumbs Up
If you are considering a petrol version of the sport, then they don't come any better than this great example.
http://www.rrsport.co.uk/forum/topic36357.html
Post #427330 Mon Jun 16 2014 7:21am
